Boost pill - yes or no?
Old Apr 26, 2009 | 04:08 PM
EndlessRed's Avatar
i couldn't get an exact answer to this, so i hope someone can help. with the boost pill, it can increase your max boost. but i've also seen in threads people that run without the boost pill and they get the same or similar result. so is there a point in the boost pill if it's going to get tuned? since i already have it sitting on my desk, should i use it regardless when i get my tune done?
Old Apr 27, 2009 | 04:05 PM
sohcpunk's Avatar
It's really up to your tuner. After the tune if he feels you need a pill he will put one in.
Old Apr 29, 2009 | 07:12 AM
HybridKOOP's Avatar
As per COBB's instruction, I have mine out for "Stage 2" upgrades. No issues with it to date.
Old Apr 24, 2010 | 10:47 PM
4G63kevin's Avatar
Bumping the dead, but I;ve one question;; I'm going to run Cobb's ots stage 1 map for a while until i get the required parts. Will I have to remove the boost pill on the stage 1 mapping? I'm still unsure about this. If anyone can chime in, I'd appreciate it. Thanks!
Old Apr 24, 2010 | 11:24 PM
brtecson's Avatar
Hardware Requirements: Otherwise stock vehicle with a STOCK INTAKE
SYSTEM and STOCK INTAKE FILTER ONLY. The addition of any other
hardware may make the vehicle perform poorly.
from http://www.accessecu.com/accessport/.../EVOXMaps.html
the "map notes" links tell you what mods are required for each map
Old Apr 25, 2010 | 12:20 AM
sbkimm's Avatar
no you dont have to, u remove it for stage 2
Old Apr 25, 2010 | 06:26 AM
eddielmc's Avatar
you might want to do some logging and check your boost level
I ran stage 2 with the pill out and I was overboosting... ended up putting the pill back
Old Apr 25, 2010 | 07:55 AM
jd888jd's Avatar
get your car tuned by a tuner using AP, theyll tune it on what mods u have on the car...just my 1cent..
whats ur mod list?
Old Apr 25, 2010 | 10:34 AM
4G63kevin's Avatar
Mod list is just a Works dropin and a Perrin catback. Workin on getting a downpipe soon.
Old Apr 25, 2010 | 12:50 PM
evosam726's Avatar
Boost!!! its one hell of a drug
Old Apr 25, 2010 | 04:15 PM
4G63kevin's Avatar
word.
Old Apr 25, 2010 | 06:15 PM
lowkey's Avatar
Registered User
Stage 1, pill in. Stage 2, pill out. Why are you unsure? It's very clear.
Old Apr 25, 2010 | 06:28 PM
403evo's Avatar
wtf is a boost pill?
Old Apr 26, 2010 | 03:21 AM
brtecson's Avatar
Basically, it's a metal piece that looks like a pill that sits in one of your vacuum lines. Removing it increases boost.
Old Apr 26, 2010 | 11:09 AM
arghx7's Avatar
On the Evo X the pill in question (there are 3) limits the amount of air that can be bled from the wastegate actuator through the two solenoids. Recall that bleeding air raises boost.
Here's how Cobb shows pill removal on a X:
The 3000GT VR-4 had a similar setup, and removal of the factory pill raises boost on both cars.
Pills are found on most factory boost control systems for internal wastegates, across different manufacturers.
On the Subarus, there is only one pill and it comes off the compressor housing (Evo X has an equivalent pill). This factory pill limits the amount of air supplied to the wastegate. When you remove this pill, your boost goes down. Recall that supplying air to a wastegate actuator lowers boost, but no lower than the spring pressure allows.
