ARC UICP and HKS Installed
Old May 31, 2009 | 12:28 AM
want_jdm's Avatar
Here is what's going on in my X as of now:
I think I'm going to need to get a tune asap. The ECU seems to be going a little nutso since it's not used to getting this much air coming in. WOT it cuts off all boost and basically runs NA. However, if I go easy on it, then the boost kicks in to about what it used stock at WOT.
Lots of power to unlock with tune! Will be getting down & test pipe by the end of the month and tune next month.
Old May 31, 2009 | 12:31 AM
Blue_CobaltSS's Avatar
nice shot of the suction kit. i kinda regret not getting that piece, the price turned me off. looks awesome tho
Old May 31, 2009 | 01:21 AM
EndlessRed's Avatar
sounds like you have a leak, if anything.
Old May 31, 2009 | 01:31 AM
want_jdm's Avatar
no leak, actually. was doing same thing when intake alone was installed; keep in mind that there is no vacuum needed for intake. you can take the whole filter off if you'd like.
Anyhow, confirmed my hypothesis with my mechanic, roadrace, and hbspeed.
Old May 31, 2009 | 02:30 AM
dcpatters's Avatar
So what was your hypothesis? Fueling is not accurate because of intake?
Old May 31, 2009 | 08:37 AM
fuzy24's Avatar
I've heard some weird things about the HKS intake and not running smooth. As far as i'm concerned, it looks the best out of all the intake options though...
Old May 31, 2009 | 09:44 AM
tomatoEVO's Avatar
wow, awesome pickups. looks great.
Old May 31, 2009 | 09:46 AM
Silver06evo9mr's Avatar
^+1
Old May 31, 2009 | 10:44 AM
EndlessRed's Avatar
i'm talking about the boost dropping to nothing on WOT. that's the first i've heard of it for doing such mods. i have something along these lines and i can go WOT like everyone else even without a tune.
Old May 31, 2009 | 10:49 AM
Hiboost's Avatar
That intake certainly costs less than the $1400 carbon fiber one. Do you have any issues when the AC fan kicks in at idle without an intake shield of some sort? As for the boost cut, likely you are getting too high in the load cells at your boost level and will need to increase those values especially in the low to mid range. You can do it with EcuFlash if you are willing to learn the basics or take it to a tuner to sort out.
Old May 31, 2009 | 12:40 PM
want_jdm's Avatar
Yeah I think this is the more technical explanation of what I am trying to explain about boost getting cut off. It is sensing a much larger load of boost and the ECU is trying to cope with it.
As far as idle goes, every once in a while after driving it hard and having AC on it will bounce between 1k and 750 rpm pretty hard.
As stated above, the ECU is just cutting off boost due to overly high load cells. I hear of many other people with similar mods having no problems, but i got mine in late January, which means that it had the new factory reflash that makes it run much leaner.
This could be a reason why the ECU is more defensive.
PS. Thanks for all the kind words!
Old May 31, 2009 | 12:45 PM
joowick's Avatar
Your ARC UICP looks beautiful, great choice.
Old May 31, 2009 | 02:07 PM
urneighborhood's Avatar
wow, that porsche and RR yours too? i have a RR sport and cayenne s too! very nice match up
Old May 31, 2009 | 02:08 PM
and we both on the same intake. very good taste. i like how it sounds so sick and gain much better high end torque
Old May 31, 2009 | 05:42 PM
want_jdm's Avatar
yeah 997 Carrera S & an HSE (non-supercharged)
