Tomei 2.3L Stroker Kit, ARMS Turbo & Complete Engine
Hey hollywood, I know what you mean about needing more jelly. I've already replaced the same part 3 times because I 'outgrew' it. Waiting for you to tell me exactly how much PB&J I need
. Damn, October 1st seems like ages from now though. PS why didn't you get it bored to a 2.5?? Because you're going to let me be the first 2.5L FP black car, right? Haha
That's my plan too, lol. As far as I can tell though, the stock sleeves are pretty beast. Neither buschur or ETS sleeves their 2.0L motors and I don't think I will be making 800whp anytime soon, lol.
^I was wondering when you'd chime in, DRAG. ERL is a 97mm stroke. I know you're not a fan of stroking the 4B11. I was mostly under the impression that that was because there were some nice high revving turbos out there like the HTA 3586. So for those of us who want to run a stock frame turbo for low-end, say with <8,000RPM redline, will stroker reliability be a problem (with the turbo near maxed on E85)?
97 and 98mm strokes aren't horrible in a 9.055" block. In the past I was more referencing the larger 102mm and up strokes in the 4G63. That 5mm extra is a lot and is hard on bearings for a regularly driven car.
I'm looking for a reliable daily driver build with more grunt down low. I am considering a 2.3 stroker with the stock turbo for now and eventually green or bbx. What's the guesstimate of gains from just the 2.3 with bolt ons? I want to make sure the bang for the buck is there.
Right but I should see a noticeable difference in the bottom end correct? Then when I do upgrade to a larger turbo the spool time should be quicker I assume. My goal is to gain more bottom end power and decrease the spool up time of a larger stock frame turbo so it's not as laggy.
Right but I should see a noticeable difference in the bottom end correct? Then when I do upgrade to a larger turbo the spool time should be quicker I assume. My goal is to gain more bottom end power and decrease the spool up time of a bigger turbo so it's not as laggy.
OakosAutomotive
165
Mar 11, 2020 06:55 AM
RallySport Direct
Oct 17, 2016 03:35 PM
Shaun@AWDMotorsports
Evo 'For Sale' Engine Internals and Drivetrain
234
Jun 14, 2016 10:37 AM
RallySport Direct
Evo X How Tos / Installations
40
Aug 17, 2015 07:46 PM
AWD Motorsports
AWD Motorsports - Florida
121
Aug 18, 2013 12:19 PM
