Evo x problem!
Old Jun 12, 2009 | 10:42 AM
goofygrin's Avatar
You are going to find out why it's called the money shift.
Old Jun 12, 2009 | 10:47 AM
skyblas's Avatar
most likely the valve are gonecase
gd luck with acquiring a 2.3l
Old Jun 13, 2009 | 01:23 AM
ImsoevoX's Avatar
Sounds like he has no compression, if the car won't turn over at all..I've been down this road with the X..it doesn't have anything to stop you from puttin the car into a lower gear past a certain engine speed. Time for a new engine..btw..if you check the plugs and one of the ground straps is bent in..that a really good indicator..
Old Jun 13, 2009 | 07:55 AM
awddyno's Avatar
dropped at least one valve and locked up the engine. that would be my guess.
Top of 2nd gear back to 1st will put that engine around 15000 rpm.
Old Jun 13, 2009 | 07:59 AM
gabeamaro's Avatar
natural selection
Old Jun 13, 2009 | 08:48 AM
slo4g63's Avatar
Wow that really sucks, keep us updated on what happened....
Old Jun 13, 2009 | 01:46 PM
Nomad4g63's Avatar
thats Mike@AWDs guess as well
NY Black momba
44
Jan 4, 2016 07:02 PM
VajEvo
Sep 7, 2014 05:01 PM
David Buschur
Oct 17, 2007 04:37 PM
AlwaysinBoost
Sep 8, 2007 09:41 AM
sleeper-s
18
Jun 10, 2006 01:12 PM
