Test pipe install was not smooth
Old Jun 25, 2009 | 05:27 AM
tsitalon1's Avatar
Hey guys,
Background:
08 GSR with 24k miles completely stock with self tune (ecuflash)
I purchased the Speedcircuit test pipe so that I could install my WB02 and do some further tuning. SC test pipe is beautiful, welds look perfect.
I ran into quite a bit of trouble removing the cat. The two rear bolts and o2 sensor were cake with some pb blaster. The two front nuts wouldn't budge...I yanked and yanked and I think I twisted the exhaust a bit as I was yanking. I ended up using a MAP gas torch and heating each nut for like 2-3 minutes each to get them loose.
So now I think i hear an exhaust leak. I felt around the test pipe and don't feel any leaks, but I swear I hear one.
I am wondering if while yanking on the two frozen nuts and twisting the exhaust against the donut gasket, I may have damaged the donut gasket. I have ordered a new donut gasket from JNZ and will see that makes a difference, I wonder how froze those bolts will be...
Anyone else run into anything like this?
I did notice that the SC test pipe is relatively thin, I wonder if the sound could reverberate and cause that sound in the test pipe itself. I do smell exhaust, but b/c I have no cat, it's hard to tell where it's coming from..
Old Jun 25, 2009 | 08:26 AM
Boostd4's Avatar
I haven't run into a single issue with this TP yet. I think you may just be hearing the difference between a cat and a test pipe. I basically just used a little bit of WD40 on the front bolts and after a little soaking they came off with a little muscle.
As far as the donut goes, I doubt you damaged it.
Old Jun 25, 2009 | 09:55 AM
tsitalon1's Avatar
Donut gasket bolts are on a spring setup right? that would mean some movement is permittable...right
Old Jun 25, 2009 | 10:18 AM
chidevildog's Avatar
I installed my TP lastnight. Prior to that I installed my CBE lastweekend. The problem you described was the total opposite for me. The two bolts closer to the engine was my problem. I got them off last night with some ease with great knowledge by one of the members here. I used my legs to push off!!!!!!!!!!! Initially they wont budge like you described. The two bolts south of the engine I used an Impact wrench no problem there. I hope you did not damaged anything...
Old Jun 25, 2009 | 10:21 AM
Hiboost's Avatar
The stock DP does have bolts with springs on them allowing some movement. If you have any exhaust leaks between the 2 bolt exhaust flanges you will see some black soot coating the heat shielding down there. If that is the case get some new 3" 2 bolt gaskets which are usually $5-$10, assuming you have all 3" connections. I know STM has them in stock typically.
Jameson_IXMR
Jan 23, 2013 12:27 PM
EVilMonkeyMR
15
Sep 14, 2011 02:18 PM
fostytou
Aug 20, 2007 08:54 AM
Warrtalon
57
Apr 3, 2007 06:14 PM
simevo
Apr 12, 2004 10:12 PM
