Downpipe with external WG on stock turbo
It'll only creep if it can't flow enough, but I'm guessing it's fine. It has a pretty nice merge with the main flow.
Its because in the picture they are using a 38mm external wastegate. You can use up to a 44mm wastegate, hence the size of the hole and step down for the 38mm
Doesn't the fact that you allow the exhaust streams to mix beyond the divided section dilute the pressure wave integrity for the dual scroll turbo? I got within a few days of fabbing one of these myself before this thought stopped me dead in my tracks.
No I highly doubt it because the stock DP isn't divided. There is still two different channels before the turbines and that's all that matters is where they get their propulsion from, not where the leftover exhaust gas goes after it's propelled each turbine wheel. Besides, the stock turbo doesn't have divided outlets on the hotside, so it doesn't matter what's after that.
Let me make sure we are referring to the same thing. I am referring to the division between the BPV channels beneath the flapper. The BPV channels exit prior to reaching the volutes. If the flapper is open (or removed) and replaced with a Tial above the BPV chamber, gases will comingle before they hit the turbo.
To take it even further, since the two volutes are of different geometry, they are going to have potentially different pressures and gas velocities. Since gas follows the the path of least resistance, if the flapper is gone and the exhaust is comingling in the common chamber, it goes to reason that the pressure wave signal is going to be muddied, mitigating the pressure wave effects that benefit a twin scroll.
It's all theory, so I guess the only way to know for sure is side by side comparison.
Quote:
"Let me make sure we are referring to the same thing. I am referring to the division between the BPV channels beneath the flapper. The BPV channels exit prior to reaching the volutes. If the flapper is open (or removed) and replaced with a Tial above the BPV chamber, gases will comingle before they hit the turbo. To take it even further, since the two volutes are of different geometry, they are going to have potentially different pressures and gas velocities. Since gas follows the the path of least resistance, if the flapper is gone and the exhaust is comingling in the common chamber, it goes to reason that the pressure wave signal is going to be muddied, mitigating the pressure wave effects that benefit a twin scroll. It's all theory, so I guess the only way to know for sure is side by side comparison. "
This is making me have second thoughts about buying this DP, does anyone else have an opinion on this?
