Upgrade Turbo?
Old Jul 14, 2009 | 05:38 PM
swingarm's Avatar
Upgrade Turbo?
In the process of installing my new O2 downpipe my turbo had to be taken out, that's not totally unexpected. The thing is now Tobz gave me the option of upgrading the turbo(FP Red) in the car since the stock turbo is sitting on His table and it would be the perfect time to upgrade it. My only question is my car is has the SST Tranny in it, would I be making a mistake by putting it in?
Old Jul 14, 2009 | 05:41 PM
Silver06evo9mr's Avatar
good luck. the trani might be comming out not to far behind the turbo
if u got the extra $$ incase something happens. go for it
Old Jul 14, 2009 | 05:48 PM
linjy2's Avatar
tune it for low boost until theres a upgraded tranny solution. but then when u do that, it would defeat the purpose of getting a fp red.
so i say stay stock turbo.
Old Jul 15, 2009 | 08:38 AM
Enjoitk's Avatar
i wouldnt try it yet haha. id wait for other people to do it and look at their results first. but im broke and cant afford the damages (if any are acquired)
Old Jul 15, 2009 | 09:10 AM
bbyevo8u's Avatar
hell NO!!
Old Jul 15, 2009 | 12:28 PM
Tractionlimit's Avatar
Just a thought, but at under 25psi, the FPRed seems to actually make less [peak] torque than the stock turbo. The gains are all in the upper RPM range or high PSI applications. If torque is what kills trannies, not HP, you should be OK.
That said, the stock turbo is great, especially in automatic, so why not just stick with that?
Old Jul 15, 2009 | 12:35 PM
DG Motors's Avatar
I honestly think an FP Red will be too much on the MR's Tranny.
We have pushed a few MR's on the stock turbo to roughly 310wtq on our dyno(dyno dynamics) and the tranny clutch started slipping slightly.
You can go low boost but if we can make the tranny slip on the stock turbo, an upgraded turbo for sure would be a waste of money IMHO!
Push the stock turbo until the tranny slips, then back off about 10wtq and you should be good to go. Utilize what you have first! Save your $$$
Old Jul 15, 2009 | 01:48 PM
swingarm's Avatar
To those who've read my original reply I've changed my mind.
I'm going to get the FP Red now(with it tuned not to destroy my tranny) then save up for clutch packs/tranny cooling, meanwhile no track time but instead the occasional very wide grin on my face.
Old Jul 16, 2009 | 06:18 AM
Hell yeah, man! I'm curious to see at what psi it slips. I actually think you'll be OK, since it won't be a torque monster like a tuned stock-turbo could be. I'm over 380WHP but under 340 ft-lbs with a Red. Power keeps building after 4K.
To those that have tuned these, do they slip high in the RPM band or low, or just at peak TQ?
Old Jul 16, 2009 | 09:46 AM
DG Motors's Avatar
It all depends on how much torque is being made. The few we have tuned started slipping right away at peak torque...We then had to back off 10-15wtq and they have been running just fine ever since.
Old Jul 16, 2009 | 09:53 AM
Olaboy808's Avatar
AMS just posted their dyno graph of their project RA w/ FP Red upgrade, and its SST held up fine. But as previously posted, the power was in the the higher RPMs, and the TQ numbers were low....
Old Jul 16, 2009 | 10:27 AM
https://www.evolutionm.net/forums/09...sst-loves.html
I lined up against this car at Great Lakes, when it first ran 12s on the stock turbo. It would definitely give me a run for my money now Kinda scary from an RA.
If torque is a limiting factor on the SST, then that's all the more reason to try an FP Red. Tune it for high RPM power.
Old Jul 16, 2009 | 10:58 AM
Olaboy808's Avatar
^^Exactly. Not hating or anything, but I must say I'm proud of the tuneability of the GSR.. I heart torque.
Old Jul 16, 2009 | 12:06 PM
meat_EVO's Avatar
do it
Old Jul 18, 2009 | 06:15 PM
swingarm's Avatar
It's here!!
It's now in the hands of Tobz.
