Stock Tune...Lean AFR (Fuel pump relay failure could damage your engine!)
Old Aug 25, 2009 | 04:34 PM
  #46
JEP's Avatar
JEP
If there was one thing I am completely lost at it is anything electrical. Please post up a how to on switching the fuel pump relay and DRL relay!!!
Old Aug 25, 2009 | 04:44 PM
  #47
JEP's Avatar
JEP
Was just on Mitsubishiparts.net looking for a fuel pump relay, had no luck is the relay just a non specific relay or is it only for the fuel pump? Chris (AMS) said he switched relays with the DRL so Im assuming any relay will work...
Old Aug 25, 2009 | 04:56 PM
  #48
WolvieDC's Avatar
chris I love you... but just not that way... thanks for the heads up
Old Aug 25, 2009 | 05:09 PM
  #49
Daskid's Avatar
Originally Posted by Gardo_Segovia
thanks for helping a n0ob
no prob!
Originally Posted by LVSBB6
Looks like we should include this relay in our service maintenance schedule.
Just ordered mine and costed CDN$40!!
So how often should we change this relay?? just to be on the safe side.
I wonder how do you make an issue a TSB? File a petition to mitsu? I think there has to be numerous complaints/incidents before they look into this....
Try to yank it out. It might just pop out from its harness. Idk, I'm at work right now so I really cant verify.
Old Aug 25, 2009 | 05:13 PM
  #50
GST Motorsports's Avatar
nj posted about this earlier this month:
https://www.evolutionm.net/forums/ev...-lean-afr.html
Here is a easier to read diagram:
Old Aug 25, 2009 | 05:23 PM
  #51
Noize's Avatar
EvoM Administrator
Originally Posted by nj1266
Today spunky and I logged an tuned his car. He nailed it. It was the bloody relay. The moment we swapped the relay, the car became pig rich during WOT. This is the first time that I was happy to see an Evo X running pig rich
There should be a sticky made with a WARNING in the title about this. This is a very serious problem for the Evo X that owners MUST be made aware of. This might lead, if it has not done so already, to a lot of blown engine.
I am very proud of Spunky. He took the bull by the horns and figured it out. I love people like that
Just saw the AMS thread on it too.
Great work you guys. I will stick it and title it whatever you'd like.
Old Aug 25, 2009 | 05:39 PM
  #52
rcboosted's Avatar
So it sounds like Mitsubishi tried to save on warranty claims for the fuel pump and as a result possibly losing engines to it.
In the DSM world, we'd rewire the fuel pump using the original relay as the trigger. Perhaps this is what needs to be done here? No actual wiring, but rewire the output of the low and high to a separate relay that will just turn on the pump at full voltage regardless. But if the relay fails, does that mean the fuel pump will keep running even when the car is off? Or it'll pop off when the key is in the off position.
Old Aug 25, 2009 | 05:45 PM
  #53
Daskid's Avatar
Great! Thanks for sharing!
Old Aug 25, 2009 | 05:58 PM
  #54
tipoytm's Avatar
Oh noes LOL, I hate to constantly check this... I wish there is an ECU logging parameter that can check voltage conditions of the fuel pump and other vital electrical components of the car.
Old Aug 25, 2009 | 05:59 PM
  #55
JEP's Avatar
JEP
thank you GSTMotorsports...
Old Aug 25, 2009 | 06:01 PM
  #56
joeyhauser's Avatar
Seems this is happening more and more.
Old Aug 25, 2009 | 06:07 PM
  #57
JEP's Avatar
JEP
Man this crap should be a TSB!!!
Old Aug 25, 2009 | 07:40 PM
  #58
MikeAce's Avatar
Found it for $24.07 Part # MR588567
http://www.trademotion.com/partlocat...?siteid=214857
Old Aug 25, 2009 | 08:10 PM
  #59
lKoRTy's Avatar
who is the manuf. of these relays, surely they have done some reliability testing on them. It should typically take at least 100k cycles before they get stuck...if its a good brand
Old Aug 25, 2009 | 09:14 PM
  #60
Tantrum X's Avatar
Wow, very good info. Thanks for the heads up.
