Meth and NO2
Old Oct 19, 2009 | 07:14 PM
kirkklau's Avatar
Question Meth and NO2
I am running fp red on 29 psi with aem meth kit with 50/50 meth, upgraded pump and 800cc injectors, cams...., (dynoed 390 whp and 330wtq)
and would like to run 35-50 shot to help on the spool and upper the hp.
do i have to tune again if i am running a "small shot" on a wet NO2 kit? retard timing needed? how do i tune for a no2 kit if i am not running it all the time. can i just keep the existing timing?
do you guys think it is ok to run meth and nos on the same car.
which kit would you guys recommend on my application?
thanks guys.
kl
Old Oct 19, 2009 | 07:23 PM
izabran's Avatar
hmmm aren't your HO a lil low??? for a red with meth? just wondering...
Talon_66's Avatar
thanks guys.
kl
Yes, yes you definitely need to retune.
Use ECUflash or CobbAP to flash between maps, 1 w/ Nitrous, 1 w/o nitrous
Old Oct 19, 2009 | 07:40 PM
kirkklau's Avatar
what do you mean??##
Old Oct 19, 2009 | 07:45 PM
kirkklau's Avatar
which kit would you recommend?
i am looking at zex turbo application set up.
http://www.zex.com/Pages/84/Turbo-Equipped.aspx
the kit will cut no2 once the boost hit a set amount of psi. on top of that, i will run a window switch probably between 2500-5000 rpm. so there are 3 things to control the no2 : boost psi, rpm and it has to be full throttle.
kl
Old Oct 19, 2009 | 07:46 PM
SyZyGy1394's Avatar
Umm just run 100% meth? dunno...
Old Oct 19, 2009 | 08:48 PM
Codevo's Avatar
You need a tune if you are planning to run any nitrous.
And as far as your window switch and boost-specific initiation of the shot you are on the right track and taking the right precautions.
However; as the old adage goes "It's all in the tune" is never more true than when tuning for nitrous on a turbocharged application.
You will need to adjust more parameters than just timing if you want to be safe AND make optimal power with said shot being used.
I, just as you am planning on running nitrous with my setup as well. However I have a built motor and feel a little more comfortable doing so...
DRAG is a member on here that you should PM and speak with personally about any questions you have being that he has used nitrous on his own evo x.
Hope I helped man, GL!
Old Oct 19, 2009 | 09:15 PM
kirkklau's Avatar
is zex a good kit to go with?
would you do direct port of single wet fogger if i want to run no2 with my Red?
Old Oct 20, 2009 | 01:26 PM
Codevo's Avatar
Zex's turbo specific kit would be a great choice.
And I would choose a direct port setup over a single fogger setup, for 2 reasons. You will make more power AND make it in a safer was as well.
