WOT engine cut out?
Old Oct 25, 2009 | 01:03 AM
►EvolutionX◄'s Avatar
Apologies SmikeEvo, Forgot about the policy.
Old Oct 25, 2009 | 04:09 AM
Smike's Avatar
No worries.
Old Oct 25, 2009 | 04:55 AM
TTP Engineering's Avatar
Fuel cut is designed to limit the intake of air into the engine not disable the car. It is momentary and regains normal operation after the limit is hit.
Old Oct 25, 2009 | 08:21 AM
xmaciek82x's Avatar
Probably hitting higher load in 4th. Talk to your tunner and see if everything still looks good in a 4th WOT. You just might need to up the fuel cut threshold.
Old Oct 25, 2009 | 10:09 AM
Pat031's Avatar
Originally Posted by ►EvolutionX◄
Driving today, my car acted as though it hit a boost cut (best way I can describe it), but half a second later, contintued to without issue. NO CEL, no warnings, no sounds from the car, just a big CHUG. Any ideas on what could have casued this?
Thanks
►EvolutionX◄
I got the same symptom after a tune. Feel like a huge hesitation. However sometime I got a CEL (Don't know what code for now but I will get it next week).
Some people said maybe I over boost, but I will get next week my Tatrix cable + a innovate WB to start data acquisition.
Old Oct 25, 2009 | 11:01 AM
kyoo's Avatar
How much power are you pushing?
I had an odd issue when my clutch was going out, where when I was WOT right at peak boost the car would actually pause or the RPMS would fall backwards because the clutch couldn't handle the peak torque - and then it would pick up right after that and continue on. Now the clutch slips in every gear. We thought it was a boost leak at first, since the RPMS would just fall instead of climbing
Old Oct 25, 2009 | 11:02 AM
buchnerj's Avatar
sounds like a fuel cut to me
Old Oct 25, 2009 | 11:04 AM
MrBonus's Avatar
Was your tank low? You could have hit fuel pick-up issues.
Old Oct 25, 2009 | 12:01 PM
Pat031's Avatar
The fuel cut is a response to an over boost condition ?
How can avoid avoid that fuel cut ? I got the feeling this is what I got too
Old Oct 25, 2009 | 12:18 PM
maxims4g63's Avatar
mine used to do that, it was a boost cut that was programmed into the (shi**y tune). it did set of the cel on occasion as an engine overboost condition.
Old Oct 25, 2009 | 12:27 PM
DirtyCookieX's Avatar
+1
I think in the other thread he did mention something about a turn or steep grade?
Old Oct 25, 2009 | 12:30 PM
mx4life85's Avatar
4th gear, WOT, about 5500 RPM probably, then chug and continue WOT. Will take a look at my plugs when I get a chance, I will just avoid going WOT for now.
Thats exactly what used to happen to me. I found out it was my engine misfire due to my spark plugs.
I went one step colder on the plugs and it hasn't happened since.
Change your plugs, esp. try to go one step colder than what the Evo X calls for.
Old Oct 25, 2009 | 02:41 PM
Thanks for all the suggestions, I'll look into these, When I get a chance I'll pull my plugs.
Old Oct 28, 2009 | 08:53 AM
atombomb33's Avatar
EvoM Community Team
Hey guys, I moved this over the Engine/Turbo/Drivetrain section. That's a better place where you'll get more of the forum "experts" involved.
Good luck with this.
Old Oct 28, 2009 | 09:34 AM
You either need to reduce the boost maps or increase the boost cut limit in the ECU mapping.
