Turbo Inlet Diameter
Old Oct 25, 2009 | 03:24 PM
Bighec's Avatar
Anyone know off the top of their the diameter of the turbo inlet? is 2.5 or 3 inches?
Old Oct 25, 2009 | 03:56 PM
Clipse3GT's Avatar
2.5 ID at the MAF
3.0 ID at the Turbo Inlet
I just measured them.
Old Oct 25, 2009 | 03:57 PM
Bighec's Avatar
Wow, thanks a million!
Old Oct 25, 2009 | 04:08 PM
Clipse3GT's Avatar
No problem.
Old Oct 25, 2009 | 04:58 PM
Hiboost's Avatar
Originally Posted by Clipse3GT
2.5 ID at the MAF
Were you eyeballing those numbers? Unless you are just reffering to the turbo inlet elbo for the turbo side and MAF piping side?
Stock MAF Pipe at connector = 76mm (2.99") ID with 82mm (3.23") OD
Stock MAF at Sensor = 72mm (2.83") ID
I don't have my stock intake piping handy at the moment but likely it's 3" ID on the MAF side and and possibly slightly smaller on the turbo end once clamped down. I sold my stock turbo so don't have the stock turbo inlet numbers either but it's likely 3" OD and less than that for ID due to the thickness of the aluminum intake elbo. I'm sure someone has these handy off the car somewhere they can measure.
Many aftermarket Turbo intake pipes are 3" all the way through at the sensor and where it couples with the turbo so they tend to throw off airflow calibrations a bit despite only being 4mm larger diameter where it measures the airflow.
Old Oct 25, 2009 | 05:02 PM
Bighec's Avatar
Interesting, and again. Thanks for all of the help guys.
Old Oct 25, 2009 | 07:03 PM
UT_EvoX's Avatar
IIRC it's 3" or slightly smaller on both ends, so I think Hiboost has it right.
initial_d2k
Apr 19, 2012 12:40 PM
Piper747
Apr 10, 2011 10:47 PM
Yamahar1
Oct 11, 2010 07:13 AM
aronjaskim
14
Sep 7, 2010 04:11 PM
SlowCar
Jul 14, 2005 09:42 AM
