blouch or fp red for evo x
Old Dec 22, 2009 | 06:20 AM
AlienEvoX's Avatar
Originally Posted by meat_EVO
why is it better to you? Did it swallow?
haha funny
but no, I just preferr the build of the Dom 2.0 plus if it ever breaks down I can get new garett internals and its fixed, and that cant be done with the FP Red
Old Dec 22, 2009 | 06:42 PM
spdracerut's Avatar
Originally Posted by HR2L
Care to elaborate on this possibility? If there was an issue with the oil feed line, it usually would be starving the turbo of oil. In my case the turbo is burning oil, not being starved of it.
Staved it just enough to damage the bearings, causing some excessive shaft motion. That in turn damages the seals on the shaft to allow oil to leak by them. One possibility among others. If you take apart the turbo, you can see discoloration due to excessive heat on the shaft if it was oil starved.
Old Dec 22, 2009 | 07:18 PM
HR2L's Avatar
Thank you for the insight. Not to sure what happened. Just took the turbo out today, and am having it shipped out tomorrow to Blouch for evaluation. Im super bummed about it, and have a feeling that its going to cost me out of my pocket for something I didn't do. I did not install the turbo, so...couldn't tell you exactly what happened other then the turbo took a dump.
Old Dec 22, 2009 | 07:22 PM
Wicked X's Avatar
I say the Tomei Arms turbo more hp then the red and spools faster the then the dom.
Old Dec 22, 2009 | 07:34 PM
chkmgnt59's Avatar
Tomei isn't out? and will cost a small fortune when it is?
Old Dec 22, 2009 | 08:34 PM
spdracerut's Avatar
Well... I know this from experience unfortunately on my Nissan. I drove it long enough though that the bearings got absolutely trashed and broke the turbine wheel off! It ended up in my cat
Old Dec 22, 2009 | 09:13 PM
Arutha's Avatar
love my FP Red only problem is the stock actutator that came with it isn't strong enough so i have just upgraded to a HKS GT actutator
Old Dec 22, 2009 | 09:20 PM
LVSBB6's Avatar
FP Green if you want torque and earlier spool! Excellent match on the MR
Old Dec 23, 2009 | 06:54 AM
GUM EVO X's Avatar
well i recently had a Dom 2 installed and tunned on my 08 MR....500 miles later (today) were under the impression the turbo seals have gone bad (nothing like a ton of bluish white smoke coming out of your exhaust when you get on boost)...kinda of pissed. The car made great power (330whp on 91 @ GST Motorsports) all the way up until the Dom 2 took a dump. Should have waited for the CBRD turbo.
We had one fail in the same way after about 1,500 miles, smoking like mad. Also had a BBK for earler model fail n about 10miles on my mates car... CBRD didnt want to warrant repair as far as I know and he now runs tomei arms turbo. Im running the fp red with no problems to date and making more power...
Regards,
GUM
Old Dec 23, 2009 | 07:14 AM
CBRD's Avatar
Regards,
GUM
im not aware of a single turbo we didnt repair that had an issue (5 of them in total now)..
cb
Old Dec 23, 2009 | 08:07 AM
ArchieBabes's Avatar
Go With FP RED
I'm in the process of installing a Blaqops Double Pumper and 2400cc HIAG Injectors running E-85 on the RED.
35PSI on the RED on E-85 should get very interesting!
Old Dec 23, 2009 | 09:11 AM
GUM EVO X's Avatar
cb
The turbo in question was supplied by coordsport in the u.k and installed and mapped by the racing line also in the u.k. The turbo came back to you not so long ago. As far as my mate is aware you guys blamed either supplier or mapper for the failure that occured after about 10 miles and coordsport left red in the face offered my mate a Tomei Arms unit at no extra cost to him... He is over the moon with the tomei product and the car is running sweet. I dont know if you did repair the turbo FOC in the end but I suspect not having spoke to a few people involved in the whole dilema.
With regards to my DOM2, that also failed however i must admit when it was fine it performed amazingly. I had a magazine feature the day after it failed so had a turbo company open it up and see the damage. I didnt send it back as I knew it had been opened and you guys probably wouldnt want to know. I got hold of an FP RED and made the feature in the end after working on the car untill 3am...
Originally Posted by ArchieBabes
Go With FP RED
Sounds simlar to what im doing
Old Dec 23, 2009 | 09:17 AM
Hey GUM,
Did you get an O2 Downpipe with your RED?
I just bought the AMS 02 Widemouth Downpipe, I think that will help a lot.
Old Dec 23, 2009 | 09:54 AM
GUM EVO X's Avatar
Hey GUM,
I run fp red, o2 housing and forge actuator... currently at about 430-440whp on dd rollers, Shoot 44 mode so no correction factor cheating crank hp is 575 and we should be in the 600's with e85
Below is my o2/downpipe combo which is made by The Racing Line in the u.k, notice no flexi joint... the right way to do it
AMS products are ace and changing o2 housings is a good move with a bigger turbo, the below picture shows the taper down on the stock unit compared to a 3inch item:
Kind regards,
GUM
Old Dec 23, 2009 | 10:33 AM
GUM EVO X's Avatar
mine running fp red@420whp:
http://www.youtube.com/watch?v=obTzmFRzFoA
