Maintence required light on!
Old Jan 12, 2010 | 08:50 PM
RREvoxGSR's Avatar
Well my car got stuck in snow today and i was trying to get out, and when i was trying to get out my maintence required light turned on and the tarmac, gravel, and snow settings disappeared. I restarted the car and it disappeared, i got kind of scared when i saw that happen, does anyone know what the problem will be?
Old Jan 12, 2010 | 09:34 PM
Rands's Avatar
Your pump that pumps fluid to your rear differential and transfer case might be burned out. Happened with mine when there was a crazy snow fall here, and -30C degree temperatures. But if the maintenance required light isn't turning on anymore after you restarted your car, it might be okay.
Old Jan 13, 2010 | 08:45 PM
RREvoxGSR's Avatar
Well I just recently changed my clutch and i changed all the fluids.
Old Jan 13, 2010 | 09:15 PM
delkat's Avatar
that happened to me once when turning into a steep drive and lifting a wheel off the ground. Re-started the car and it never came back.
