Raise launch ctrl with FP Red?
Old Mar 1, 2010 | 09:49 AM
dragon831's Avatar
I'l be getting an FP Red installed soon and was wondering if i should go ahead and have them increase the launch ctrl? If so, to what?
Old Mar 1, 2010 | 04:02 PM
NZEvox's Avatar
If it was me i would wait till i have the red installed do a launch and see if it bogs or not then adjust accordingly.
Old Mar 1, 2010 | 04:12 PM
mlomker's Avatar
I was reading a thread the other day and someone threw out 6200rpm. Not sure why that number was picked but there you go.
Old Mar 1, 2010 | 04:58 PM
dragon831's Avatar
yea i've seen 6k and 6200 so far.
Old Mar 2, 2010 | 01:59 PM
steinvb12's Avatar
You could do 6K if you want. Mine is set to 6k with the stock turbo. I see about 8-10psi off the line and usually end up spinning.
Not sure how it would be affected on the red as spool up times are different. But if you are already boosting off the line, then you will have plenty of power. The question is can you keep it from spinning?
Old Mar 2, 2010 | 02:54 PM
Brokenevo's Avatar
I would really suggest, if your going to do a lot of launching, you should really prepare your drive train! I know Bushur makes some center differential pin up grades, and I would worry about that as much as anything else. Broken tranny is not fun!
Old Mar 5, 2010 | 12:40 AM
SilverEvoX's Avatar
I wouldn't increase it, it will just spin big time. I lowered mine on the stock turbo down to 5k from the 5468 or whatever the stock one was because even at 5k i was getting a fair amount of wheel spin and that's with my direzza star specs in the stock size. Granted this is on the street, at the track I'm sure it would hook at 5.5k
Speedlimit
EvoM Announcements
Sep 16, 2015 04:43 AM
jcsbanks
Jun 9, 2011 11:45 AM
Redline06
56
Oct 21, 2009 11:59 AM
anjapower
Jun 5, 2006 07:19 AM
