Help with Agency Power BOV install
Old Mar 10, 2010 | 04:08 PM
koach's Avatar
I bought it used so there were no instructions. I'm trying to follow the install on their site, but the images are broken: http://www.agency-power.com/blog/tec...-installation/
I got it installed and everything works great, I just have a question about steps 6 through 8. Since I do not have the pictures I do not know how it is setup. I can hear the BOV loud and clear so it is 50/50 or 100% VTA. I didn't notice a black plastic plug anywhere so I assume it is 50/50. I emailed the seller waiting for confirmation. I don't understand the part about "Adjust desired opening by using the adjustment screw on top of the valve"
Does this determine how much air gets vented out? And I assume it is referring to the valve on the back of it by the firewall?
Thanks.
Old Mar 11, 2010 | 08:04 PM
shyong's Avatar
i'd sell it if i was you. Ran into problems with it leaking boost when I had my X tuned. Absolute garbage.
Old Apr 4, 2010 | 02:15 AM
MYEVOXGSR's Avatar
i use to have that bov in my evo but i sold it because you can actually hear it when you have stock pipes.. anyways.. the black plug is to close the recirculation hose on the intake that is your choice of benting the bov or recirculating it,, also the bolt in the top is if you want your bov to go long with all the air or really short.. but you should leave it in the midle because it might cause leak or surge..
Bananayellowevo
Nov 30, 2016 07:07 AM
Strangways
Canadian
Aug 28, 2015 07:22 PM
Strangways
Canadian
Aug 14, 2015 12:54 PM
Acewolf
45
Dec 11, 2012 11:14 AM
p1llar
13
Feb 21, 2012 12:09 PM
