Oil Residue inside the Turbo Outlet pipe
Old Mar 27, 2010 | 04:27 PM
FetorHepaticus's Avatar
I was installing my new UICP when i noticed what looks like an engine oil (dark brown) residue inside the turbo outlet pipe, it's not a lot though.
I'm aware that the turbo is lubricated with the engine oil.
Is this normal?
Thanks.
Old Mar 27, 2010 | 04:33 PM
vanilla2's Avatar
Do you have an aftermarket oiled filter
Old Mar 27, 2010 | 04:44 PM
alianum777's Avatar
+1. It's usually signs of the inner seal getting worn. When it gets really bad you will start seeing your air filter get saturated.
Old Mar 27, 2010 | 04:59 PM
SiC's Avatar
SiC
Excessive blow-by can cause this
spdracerut's Avatar
Generally, it's from oil getting recirculated through the PCV system. Yes, it's normal.
Old Mar 27, 2010 | 05:05 PM
vanilla2's Avatar
This is what I originally thought but was just checking to see if he over oiled his k&n. Install an oil catch can and search. Good luck.
Old Mar 27, 2010 | 05:14 PM
no oiled air filter, using oem panel filter
Old Mar 27, 2010 | 06:02 PM
stokEd's Avatar
Then it's probably what spdracerut suggested.
Old Mar 27, 2010 | 06:10 PM
evo unknown's Avatar
Blow by is quite normal. However, the amount may not. I started noticing blow by in my intake pipe on my evo 8 being recirculated through the system and put back in there. This was then going into the turbo and intercooler lines and intercooler. I installed a catch can, and so far so good.
Old Mar 27, 2010 | 06:14 PM
BigT's Avatar
Get a catch can.
The stock crank case pressure system is designed for a stock boost levels. Replace your pcv valve and get a catch can on the line going to the intake and everything will be ok.
However, there should be minimal oil residue. If you have a pool of oil or a good amount, you have other problems.
Old Mar 28, 2010 | 01:30 PM
Thank you very much for everyone who responded.
The oil residue is minimal i would say, it's not runny of dripping.
Old Mar 28, 2010 | 01:42 PM
heavyD's Avatar
As mentioned it's from the PVC system, is normal and is nothing to worry about.
Old Mar 29, 2010 | 10:52 AM
Thegame's Avatar
I attempted to install a catch can to prevent this, but it ended up still getting through. I think I tried a universal Greddy can and switched to a Perrin can without any better results.
Old Mar 29, 2010 | 10:56 AM
solarevo's Avatar
completly normal, a little oil does the turbo good =>
Old Mar 29, 2010 | 11:05 AM
SyZyGy1394's Avatar
But not the intercooler.
