Boost leak test qs
Old Mar 29, 2010 | 06:49 PM
GR33DY's Avatar
Boost leak test qs
What size is the TURBO INLET on the X ?
Need the size so I can make a BOOST LEAK TESTER.
Im trying to do a boost leak test at the TURBO INLET. Is there anything I need to plug up or do I just connect the tester to the TURBO INLET and pressurize the system then listen for leaks ?
And should I connect the BOOST LEAK TESTER anywhere else to test for leaks? or is the TURBO INLET suffcient for a test.
Old Mar 30, 2010 | 07:46 AM
RMGST's Avatar
Seen this?
https://www.evolutionm.net/forums/ev...er-5-02-a.html
Old Mar 30, 2010 | 07:51 AM
MR. Tim's Avatar
Sweet.
