Convert SST to Manual
Old Mar 24, 2010 | 04:37 PM
Rallyman's Avatar
How difficult would it be to convert an Evo X SST to manual transmission.
Does the SST use the same gearbox mounting points, are the drive shafts the same, will the engine crankshaft accept a manual gearbox flywheel and clutch etc.
I would like to convert my car so it could be used for competition if possible.
Any help would be much appreciated.
Old Mar 24, 2010 | 04:40 PM
Mike Bones's Avatar
Idk what your monetary situation is but I think from a price standpoint, it wouldn't be worth it.
Old Mar 24, 2010 | 04:41 PM
malymabl97's Avatar
it may be easier to trade in the car for a gsr.
Old Mar 24, 2010 | 08:49 PM
kozmic27's Avatar
The SST is so expensive, I would immagine you could cover most of the cost of the conversion by selling the SST. I am actually doing something similar on my SMT toyota MRS. Start by finding a total, and buying everything off it you can. Should be doable.
Old Mar 25, 2010 | 10:37 AM
ETS Michael's Avatar
Sounds like a fun project!
Old Mar 26, 2010 | 06:08 AM
MicMcKee's Avatar
I could see that maybe being worth it if you've got the touring package,
Old Mar 26, 2010 | 06:19 AM
hotdog's Avatar
You could do higher quality leather and sound deadening for a whole hell of a lot cheaper than a tranny swap.
Old Mar 26, 2010 | 06:24 AM
MicMcKee's Avatar
There's a lot more to the Touring than just leather and deadening...
Rain-sensing wipers, Sun-roof, etc...
Not saying it's practical, just the only possible reason I could see it happening...
Old Mar 26, 2010 | 12:43 PM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Well as was stated last time this question was posted don't forget you have to add a third pedal, not saying that it cannot be accomplished it just sounds like a lot of work. Good Luck!!
Old Mar 27, 2010 | 04:14 PM
Jblade's Avatar
I guarantee it will be easier to trade in the car for a gsr
Old Mar 27, 2010 | 05:43 PM
stokEd's Avatar
He's talking about using the car for competition, probably not concerned with leather, etc ...
@Rallyman If it's possible to sell your GSR and pick up an MR/GSR w/SST where you are, that's probably your best bet.
Could be a fun project though. You would need to find a donor car for sure. The list of things you'd need is pretty substantial:
Transmission
Motor Mounts
Front Axles
Transmission Cooler
Trans Cooler Lines
TCU
Shifter Lever
Shifter Paddles*
Gauge Cluster*
Electrical Harnesses (TCU, ECU, gauges,...)
ECU Reflash (might have to swap ECUs as well)
*may be optional for a competition-only vehicle
You'll also need to find out is if the firewalls are different between the 5-speed and SST. The five speed has to accommodate the clutch pedal and master cylinder, which the SST of course lacks, so that could be snag.
This is all I could think of, I've probably omitted a few things.
Old Mar 27, 2010 | 06:20 PM
MicMcKee's Avatar
Transmission
Motor Mounts
Front Axles
Transmission Cooler
Trans Cooler Lines
TCU
Shifter Lever
Shifter Paddles*
Gauge Cluster*
I missed the competition part,
And correct me if I'm wrong but he wants to go from SST to Manual,
You've described the opposite
Old Mar 27, 2010 | 07:07 PM
rogue's Avatar
Originally Posted by micmckee
i missed the competition part,
and correct me if i'm wrong but he wants to go from sst to manual,
you've described the opposite
lol.
Old Mar 27, 2010 | 10:37 PM
stokEd's Avatar
lol...
Old Mar 27, 2010 | 11:05 PM
Hakmeister's Avatar
so any actual price on how much it would cost, it might be worth it if you can sell the old sst if you swap it
