Boost Leak test AND valve overlap
Old Apr 3, 2010 | 10:35 PM
tephra's Avatar
H Guys,
Just trying todo a boost leak test, but at about 1bar the 'boost is leaking in the engine' lol... and my little compressor wont push psat 1bar
does anyone know what degrees i need to be at so all the valves are closed?
How can I tell without taking the cam cover off?
Cheers
D.
Old Apr 4, 2010 | 01:26 AM
tephra's Avatar
ended taking of the throttle body hose, and plugging up the BOV line...
2bar tested
busted my throttle body hose putting it back on thou.... oops too tight :|
Old Apr 4, 2010 | 01:41 AM
evogirl916's Avatar
i made a little rubber coupler that goes right on the turbo with a end cap/valve stem on the other side. pvc primed and glued everything and use the stock clamp to secure it. holds 30+ psi, but pressure still bleeds from the boost control silenoid...unless you plug it
Old Apr 4, 2010 | 01:46 AM
tephra's Avatar
yeah thats how I used todo it, but after hearing that the turbo seals leak I thought I would bypass the turbo...
Old Apr 5, 2010 | 06:21 AM
MR. Tim's Avatar
So you ran the test post turbo? So from the inlet of the UICP? Actually due to location, that is easier than removing a bunch of stuff to plug into the turbo inlet.....
Old Apr 5, 2010 | 07:45 AM
tephra's Avatar
since I have stock IC piping I just disconnected the expander joint in the UICP and started from there...
Old Apr 5, 2010 | 07:49 AM
chidevildog's Avatar
have you got the results from the test?
Old Apr 5, 2010 | 10:42 PM
tephra's Avatar
yeah I got upto 2bar and it held ok..
i am still interested in doing a full test, so if anyone knows how far past TDC all the valves will be closed please let me know
Old Apr 6, 2010 | 01:46 AM
SiC's Avatar
SiC
Lets see, firing order is 1-3-4-2 so that means at TDC:
Cylinder 1 is about to combust (intake valve closed)
Cylinder 2 is about to exhaust (intake valve closed)
Cylinder 3 is about to compress (intake valve about to close)
Cylinder 4 is about to intake (intake valve about to open)
It's hard to say what degree exactly since you have to know the exact cam opening/closing degrees, take in consideration the valve clearance, etc. But by knowing the sequence above, it should be a few degrees after top dead center right when cylinder #3 intake valve is closed. If you go too far ATDC cylinder #4 intake valve will open.
Place the engine in TDC (be sure it's TDC cylinder #1 and not #4 ), apply the compressed air into the intake and rotate the crank clockwise until the leak stops.
Old Apr 6, 2010 | 02:11 AM
SiC's Avatar
SiC
Actually it shouldn't matter, it can be ATDC for any cylinder
But know that I think of it, I wasn't thinking about overlap which occurs between the end of the exhaust stoke and the begining of the intake stroke. This maybe a little harder than the easy thinking above
Easy way, just keep rotating the crank until the leak stop
Old Apr 6, 2010 | 02:15 AM
tephra's Avatar
yeah i tried trial and error but that didn't work too well
i will start at TDC and go forwards from there..
Old Apr 6, 2010 | 02:42 AM
SiC's Avatar
SiC
When #1 is at TDC #4 should be in the middle of overlap. If you keep rotating the crank clockwise overlap will end and #4 intake valve will open further but at the same time the #4 exhaust valve will fully close. So as long as your cylinder isn't leaking, you should still have a good seal even with the intake open. So this means it should still be some degees ATDC when #4 overlap ends
Old Apr 6, 2010 | 03:48 AM
tephra's Avatar
yeah ok - thats all that matters - exhaust valves being closed
so you think slightly after #1 is at TDC? so start just before and work forwards..
#1 being closest to timing chain yeh?
Old Apr 6, 2010 | 03:50 AM
SiC's Avatar
SiC
Yeah, slightly after #1 TDC when the #4 exhaust valve closes all the way.
Yes, #1 is timing chain side
Old Apr 6, 2010 | 03:52 AM
vboy425's Avatar
We have the same issues on our race evo with our race cams. I just take the cams out and be on with the test.
