Intake question
Old Apr 14, 2010 | 11:03 PM
blincoln423's Avatar
Intake question
So im considering the ETS intake or the ams intake for my 2010 X and i was wondering if it would cause any harm to my car if i put it on and ran it without a tune since the car is daily driven.
Old Apr 15, 2010 | 01:50 AM
Freebs's Avatar
A lot of people will say you need a tune but you don't... I have yet to hear of an engine blowing up from just adding an intake... Also check out the Harmon Motive intake if your looking at AMS... Exactly the same just $100 or so cheaper and it comes standard with all the bungs you need to just bolt it on and go where as with the AMS intake thoughs are all extra $$
Old Apr 15, 2010 | 05:54 AM
tonyboy's Avatar
^^one of the reasons why they are suggesting that get a tune with an intake (like AMS or Harman Motive) is because intakes that changes the size of the maf housing messes with your STFT's and LTFT's..
intakes that utilizes the stock maf housing like nisei, br, etc. "can" technically be installed without a tune..but then again not all cars are alike..so that's why it is recommended to have your car tuned.
Old Apr 15, 2010 | 06:06 AM
ugakirk's Avatar
I would be more careful about doing an intake without a tune on the 2010's than an '08 because the tune is leaner. I don't know how much leaner, but it is a good bit.
Like the OP said, I haven't seen an intake blow a motor on a X yet, but the '08's tune is **** rich so that probably why.
Old Apr 15, 2010 | 06:08 AM
9evolution's Avatar
What are STFT and LTFT?
Old Apr 15, 2010 | 06:10 AM
DepoRacing's Avatar
k&n typhoon seems like a good one
Old Apr 15, 2010 | 06:12 AM
sofly1990's Avatar
guys would evo x intakes fit the 09 ra? i should be relocating the battery to the trunk soon
Old Apr 15, 2010 | 06:15 AM
bluepeartype-s's Avatar
Registered User
I've also been looking at ETS and AMS and heard that it can make the idle more sporadic (MAF?)...anyone experence this with either?
-B
Old Apr 15, 2010 | 07:26 AM
tonyboy's Avatar
this would be your fuel trims.. STFT = short term fuel trims; LTFT = long term fuel trims
Old Apr 15, 2010 | 07:52 AM
stlgrym3's Avatar
another newbie question. will tuning your car void the factory warranty?
Old Apr 15, 2010 | 01:24 PM
Rands's Avatar
I think it depends on the dealer, and depends on the situation.
For example, if you got your car tuned by a crappy tuner, and it caused your car to run ultra lean resulting in a blown engine, then I can see that voiding your warranty.
But if you got your car tuned, and you brought it back for recalls and they see that your ECU has been tampered with, that could depend on the dealer.
Old Apr 15, 2010 | 04:28 PM
TruSlide's Avatar
i spoke with a tuner a week or two ago, we were talking about the A/F ratio out of the factory and the tuner said it's like 9:2. So... if an aftermarket intake causes you to run a little bit more lean, shouldn't be too bad...
Old Apr 15, 2010 | 07:43 PM
revolution12's Avatar
you will be fine, i drove around for a couple of months with no tune, it will run kinda weird at idle might jump a wee bit but nothing to worry about you will be fine but another reason to get it tuned is to just make more hp a tuner can pump out a ton more extra horsepower by tweaking things so its always good to get a tune!
Old Apr 15, 2010 | 08:42 PM
JebusMKIV's Avatar
As stated already, you should get tuned when you get an intake, especially if you go with AEM.
Old Apr 16, 2010 | 08:52 AM
ETS Michael's Avatar
** Works with stock intercooler piping!!
We don't have the problem with the crazy idle due to the shield we provide. Attached is a graph of our dyno sheet with no tuning, bolting the intake on and putting on a boost controller (22psi).
56whp over stock!! No Tuning!!
We also use a 5.0" inlet that returns back into the stock MAF housing so you won't need to rescale the MAF with the ETS intake. Our filter has one of the largest surface areas on the market!
This intercooler will not fit the Ralli-Art, but we do have an intake for the RA not yet on our site! Send a PM if interested.
LINK: ETS Evo X Intake
Thanks!
Michael
