new clutch in.. not sure if its wrong or what.. help please!
hey guys, i got my clutch changed to the Exedy stage 1 and ACT lightweight flywheel. This is my first clutch change n the car feels really different. Not sure if its the shop installing it wrong or I don't get how to drive it yet.
1) the clutch pedal vibrates.. from initial step to engagement point, it vibrates hard. can make my feet numb. doesn't vibrate when it's fully depressed.
2) The car is really hard to get off on first gear now. On a complete stop, if i left go of clutch just a little, car stalls.. need some gas to just get the car moving.
3) I can't get into gears half the time.. on the drive home, if I double clutch, I can get into gear easily.. say driving at 50mph and I'm in 4th gear. I fully depress clutch, I just can't get into 5th no matter what. Have to let go of clutch, then clutch again to get in. same goes for almost every gear.. but random times I can go in easily. Is there a trick to getting into gear for the Exedy clutch?
4) There's some loud noises when the clutch is engaged. From outside of the car, it sounds like metal hitting metal. pretty loud.
soo help plz? is there a break in period for clutch too or something? its annoying I can't get into gear..
how can u check that? im no mechanic and the clutch install shop is 50 miles away..
I researched a bit.. the shudder and stuff I'm sure it'll go away. my biggest problem is just not able to get into gears..
what causes a non broken in clutch to vibrate? when i bought my car with 17 miles on it, It had no such vibration.. pretty sure mitsu didn't break it in for me.. Although I heard the metal to metal contacting noise.. CLANK CLANK
this should help you. http://www.evomoto.com/tech_info.php?tPath=1&tech_id=28
as for the gears can't engage, he said it might be that he didn't bleed my clutch fluid. anyone know which fluid it is or know how to do this? I'm gonna try this n see if it helps.
bbong
Jun 11, 2017 05:25 AM
Jacks Transmissions
Jacks Transmissions
50
Feb 20, 2016 02:54 PM
TitanMotorsport
Oct 22, 2009 10:09 AM
sleeper3
20
Jun 19, 2009 03:37 AM
