DIY - 4B11T Engine upgrade questions
i think you need torx bits to get the headstuds out...
you will possible need a honer to re-hone the bore... i am not sure if the $70 ebay item with a drill is ok or not
socket set for the rest of the bolts
probably some sealant for the rocker cover
ring compressor for the piston rings
feeler gauge to measure gaps
torque wrench to torque things up properly
hammer for when things go wrong :P
If you're rebuilding a 4B11 with aftermarket forged pistons (or even the stock ones), absolutely do not use those ring gaps. I know not everybody agrees with certain shops, but a few of them are 100% correct about the stock ring gaps being too tight. Mitsubishi probably did it for emissions purposes; I couldn't imagine another reason to gap rings so tightly on a turbo engine.
R/TErnie
80
Jan 7, 2021 02:46 PM
dambikeracer
25
Sep 14, 2015 10:44 AM
High_PSI
Apr 10, 2012 02:56 PM
