Can you do rod bolts without taking the ...
Old May 4, 2010 | 12:41 PM
  #31
GST Motorsports's Avatar
Yup once you vent that block the $$$$ skyrockets, although I don't agree with drop-ins but I'm also not an engine builder.
- Bryan
Old May 4, 2010 | 12:43 PM
  #32
murlo26's Avatar
- Bryan
Out of curiosity, what would you recommend? Sleeve it and all?
Or are you saying, keep the stock motor...
Old May 4, 2010 | 12:48 PM
  #33
I'm in the camp of doing a proper engine build, with the motor out of the car so everything can be balanced and checked, yada yada.
Again, I'm not a engine builder but I believe buschur and AMS have found no need for sleeving the 4B11... I could be wrong though, as I am not an engine builder.
- Bryan
Old May 4, 2010 | 12:53 PM
  #34
murlo26's Avatar
- Bryan
Oh, yea, well that is going to happen, at least with my car. It will all be out of the car and all the clearances and etc will be checked.
I see what you are saying though, rather than just pulling the head and leaving the motor in etc.
I guess mine is a "proper" build, not by choice though, lol. Well it will be.
Old May 4, 2010 | 02:07 PM
  #35
mlomker's Avatar
I like the 'proper' idea as well. It's the extra kilobucks in labor that I wasn't inclined to deal with.
Gates' brand new motor failed, so obviously there's no guarantees with anything you do.
Old May 4, 2010 | 02:16 PM
  #36
ETS Michael's Avatar
No Sleeves here Drop in Pistons/Rods. You can also change the rod bolts with the motor in the car, just drop and pan, etc. We pushed the stock block to 680whp with countless dyno pulls and daily driving before the rod bolts let go.
Michael
Old May 4, 2010 | 06:06 PM
  #37
bouncintiga's Avatar
Michael
and what happens when the rod bolts let go...
Old May 4, 2010 | 06:17 PM
  #38
HR2L's Avatar
You do an unscheduled oil change out the back of your block!
Old May 4, 2010 | 08:36 PM
  #39
murlo26's Avatar
^That, then the ground looks like this...
Old May 5, 2010 | 05:46 AM
  #40
mlomker's Avatar
Do you recall what the torque was? I'm not convinced that hp is the problem. It seems that we've had a lot more cars with stock-sized turbos have motor failures than the large turbos (which tend to have high hp and modest tq).
Old May 5, 2010 | 06:02 AM
  #41
tephra's Avatar
680 whp @ 8000rpm:
680 = tq * 8000 / 5252
= 446 tq
680 whp @ 7000rpm:
680 = tq * 7000 / 5252
= 510 tq
Old May 5, 2010 | 09:40 AM
  #42
Your block receives a window.
Old May 5, 2010 | 09:45 AM
  #43
MarkM's Avatar
darton sleeves in mine, as my bores were scored
Old May 5, 2010 | 10:07 AM
  #44
tsitalon1's Avatar
Michael
Mike,
Would it be your suggestion to install dropin Pistons/Rods if the goal is 400whp for a DD? Or do you think it's not neccessary at that power level to maintain reliability?
Old May 5, 2010 | 10:12 AM
  #45
murlo26's Avatar
^I say again, if you can afford drop in's, do it.
I am probably going to end up parting my X out and selling it. Looking to go Evo 9. Little cheaper and wider array of parts. Plus I don't want a $60,000 evo right now, perhaps over time, but this is too much to stomach at once.
