Can you do rod bolts without taking the ...
Hi Guys,
According to http://www.turbomagazine.com/tech/08..._oil_pump.html
Tomei reckon the rods in the 4B11T are STRONGER than the 4G63T... But the rod bolts are probably weaker.
Does anyone know if you can change the rod bolts by just taking the lower portion of the oil pan off?
Thinking about doing this....
Obviously the labour required for such a modification would be pretty minimal....
Cheers
D.
Cheers
D.
ok after reading back through various other threads it would seem that doing rods is probably a good thing - maybe the manufacturing process of the factory rod is producing bad rods (since they are designed better than the 4G)
so the next question:
can you do rods from the bottom? ie remove both parts of the oil pan, and crank, can you pull the piston far enough down to pull the pins out?
basically I want maximize the gain by doing minimal work
My tuner told me rod bolts weren't worth it...he said the rods themselves seemed to be the weak spot and just doing rod bolts probably wouldn't help much.
So he recommended doing full drop in's if anything. So i faced leaving the motor stock or full drop ins. I chose the stock motor and it let go...lesson learned. If you plan to push it, do drop ins!
not worth just doing rod bolts, since the engine has opened up, do at least head studs, pistons + rings, con rods minimum at least. but it's just my 2 cents.
when the engine being pushed, normally rods are the main problems and seen many of these cases or if a tune went wrong pistons start to melt, chip, rings worn, and holes too.
well you can do rod bolts WITHOUT taking the head off... just the oil pan and windage thingy
i have no doubt that a full drop-in would be harder than most peoples capabilities, but you know me - always like to try things myself
I don't see any reason why you couldn't.. You could do them in the 4G63 as well. It was kind of a pain in the butt though, mostly because the bolts are a press in fit, so you will need to find a way to get them out without removing the rod. You could leave one bolt in, and tap the other without the nut on with a hammer and drift punch to pop it out, and use the nut to pull it back in.
hehe
