Best Fuel system solution for my car E85
Old May 4, 2010 | 01:45 AM
hotdog's Avatar
Originally Posted by doghead
I have googled the name, searched the forums, ex........... I still can not find their website or anyone that sells their kits.
You might have a mental problem then.
http://lmgtfy.com/?q=blaqops
Old May 4, 2010 | 02:39 AM
churchja's Avatar
That's hilarious!!!
Old May 4, 2010 | 05:48 AM
Gsxtremedsm's Avatar
Originally Posted by RB185AFM
I just had the opposite happen to me this weekend. I wanted to see where my 1000 CC injectors would max at with my 6262. So before I did my pump tune I had Bryan tune my car on E85 with DW 1000cc and a single in tank walbro 255. We could only make 408 before the injectors were maxed. On my turbo that was only 20 lbs. The pump still had more in it. But we did stop at 98% duty cycle to maintain a buffer.
Just because you were at 98% cycle duty doesn't mean you were out of injectors. Most likely out of fuel pump. I read on an older buschur fuel pump test that when they switched to something with more pump... The injector duty dropped considerably. Also gates' blue ams evo made well over 500whp on E85 with 1000cc dw injectors.. Somehow haha
Old May 4, 2010 | 06:13 AM
goofygrin's Avatar
I'm running DW 1000's on E85 on the stock turbo @ around 80% IDC (375hp/400tq on a mustang dyno).
I have a 255 in the tank feeding a surge tank that feeds another 255 that feeds the rail.
Old May 4, 2010 | 06:40 AM
Evofreak21's Avatar
So it is safe to say if I have FIC1100's and a double pumper from Blaqops, that this will support anything my little heart desires.
Old May 4, 2010 | 07:34 AM
mlomker's Avatar
You could use an afpr and a higher base fuel pressure to out-run the single Walbro if you want to. GST's dyno is not high reading...it's similar to the one that I tune on. 800cc is good for around 320 and 1000cc is good for around 420 (with an afpr and 2-3 psi over stock).
If you look at the flow info that came with your injectors you'll discover that they aren't actually 1000's. DW1000's, for example, often flow at 1040 or 1050.
Old May 4, 2010 | 07:57 AM
goofygrin's Avatar
No. You could potentially run out of injector. If you really want big HP I'd look at the DW1500s... esp. with E85.
Old May 4, 2010 | 08:18 AM
I agree E85 takes a lot of fuel.. the only reason I would run 800cc injectors right now is because I have an accessport. and an off the shelf map will suffice right now.. The way I look at it is I can gain about 50hp for $360(injectors) $385(ams fuel kit) and minimal effort in labor..
Then in 3-6 months or so I'll be doing cams, turbo, (bigger injectors.. Selling old ones) along with clutch and AMS or Buschur E85 tune.
Unless someone knows how to modify the cobb off the shelf E85 map for bigger injectors?..! All I'd have to do is change the injector scaling and latency, but to what and how on an AP?
Old May 4, 2010 | 08:35 AM
HiI'mDustin's Avatar
get a double pumper and 1500DW injecotrs or ID2200
Problem solved
Old May 4, 2010 | 08:41 AM
goofygrin's Avatar
Don't waste your time with an OTS map. Even if you have to wait a bit to save up the $$, get all the parts and get a good custom tune... ONCE.
Your plan seems reasonable in the short term, but speaking as someone that's done that plan, it SUCKS and costs you money.
Old May 4, 2010 | 09:07 AM
mlomker's Avatar
Originally Posted by HiI'mDustin
get a double pumper and ID2200
That's what I did but the big fire hoses don't run pump gas very well. It's fine if you'll never run anything other than E85, like me.
I am me
33
Mar 21, 2015 11:03 PM
Strictly Modified
Dec 2, 2014 10:05 AM
EvoX-11
Jul 5, 2013 06:17 AM
mlee25
33
Dec 11, 2011 01:21 AM
mplspilot
E85 / Ethanol
135
Oct 14, 2010 05:39 PM
