injectors or fuel pump first?
Old May 8, 2010 | 07:44 PM
lousEVOxmr's Avatar
hey guys ,
im getting cams next week, prob with springs ...
what should i buy and instal first or i should say what will i need first .???
injectors or pump..??
right now ..
ets 3.5,upper,mbc,turbo back,ams intake+shield ..tuned...
Old May 8, 2010 | 07:49 PM
BerserkerX's Avatar
Not a X owner but I would say pump first. My pump ran out of fuel pretty quickly. Haha not to mention it was a lot cheaper to get a pump. Its not a perfect practice but when my injectors started hitting their ceiling I upped the latency and that allowed them to run past what they normally would. I blew fuel fuses though because of it..
Old May 8, 2010 | 08:20 PM
BigT's Avatar
the X's pump flows substantially more than the prior models. I say go for injectors first.
Old May 8, 2010 | 08:27 PM
mlomker's Avatar
Yup. Someone recently tested the stock pump and it was good to 480 on their dyno. Plenty for stock turbo unless you go E85.
Old May 8, 2010 | 09:11 PM
tsitalon1's Avatar
Do the injectors first!!! Been there and done that.
Old May 8, 2010 | 09:40 PM
tephra's Avatar
injectors..
Old May 8, 2010 | 11:27 PM
lousEVOxmr's Avatar
a nother question whats the max output of 800cc?
whp xxx=800cc?
i m not planning on running e85 bc theres none in my area..
Old May 9, 2010 | 12:28 AM
E6-X's Avatar
injectors first. rated 600cc and should be able to get you to approx. 350whp (depending on fuel type & setup) with little or no probs but do not it is rated not guaranteed.
just my 2 cents
Old May 9, 2010 | 01:44 PM
Golden's Avatar
I was running E85 on the stock pump and still was able to hit 10.5 AFR (gas scale) at 7000 RPM with no issues. And yes that was very rich, but I still hit it.
(Note: I had FIC1100's installed)
Old May 10, 2010 | 09:49 AM
SilverEvoX's Avatar
whp xxx=800cc?
800cc on Pump Gas should be able to support 450ish whp which is more than the stock fuel pump can handle for sure. A single walbro and set of 800's would be ideal if you're staying around that level.
Old May 10, 2010 | 10:06 AM
BerserkerX's Avatar
Its good someone else came in here. I have always been told pump but that is on a IX. Is there a way you could do both at the same time right now man? That way its just done and out of the way.
Old May 10, 2010 | 10:31 AM
lousEVOxmr's Avatar
ya but im putting cams,springs,injectors,brakelines,......(prob,clut ch upgrade with seals).. so my buget is tight lol..
i was trying to eliminate a few dollars lol
Old May 10, 2010 | 01:28 PM
04gsr's Avatar
the pump is fine for your mods, just get injectors.
Old May 10, 2010 | 02:29 PM
lowkey's Avatar
Registered User
Here's a calculator.
http://www.deatschwerks.com/catalog/...alculators.php
With the mods listed on 93 octane you will probably be around 340 whp / ~400 at the flywheel. If you use a BSFC value of .6 and target duty cycle of 80% you will need 800 cc injectors.
Old Sep 6, 2010 | 09:36 AM
JED_POLAND's Avatar
Are you saying that the stock pump should be OK with maxed-out stock turbo and stock injectors?
What if I throw in DW 800cc? Still OK?
Need to know ASAP, please.
Supporting mods : BC 272, TBE, FMIC, UICP, etc.
