IC piping.....
Old May 31, 2010 | 06:42 PM
ETS Michael's Avatar
If you have a minute, check out ours at http://www.extremeturbosystems.com
We build ours in 100% stainless steel piping, bead rolled edge, 4 ply silicone and works with the stock air box and blow off valve as well
Fits both MR and GSR
Thanks!
Michael
Old May 31, 2010 | 08:14 PM
EndlessRed's Avatar
Originally Posted by hotdog
There is no difference, if the stated diameters are the same. Unless you go with a real ****ty off brand, they're all going to fit, they're all going to work, they're all going to be shiny pieces of pipe.
Pick your favorite brand of shiny metal, and buy it.
The only big savings you might be able to warrant is by doing package deals; call AMS up and say you're looking to do one of their shortblocks in 2010, and they might bang off some bucks off their IC kit.
Welcome to marketing. My badge is better than yours, and I prove it by paying more. Flex flex.
well...to be exact, there are SLIGHT differences in different UICPs. for example, agency power's reroute the blowout valve to the top instead of from the LICP. Nisei's UICP is a one-piece pipe, while most on the market is a two-piece. ARC's pipe is full bling blingin' titanium (minus the aluminum elbow), etc.
at the end of the day though, it's really all the same. pretty much all the reputable brands have the same bead ends, stainless steel, similar couplers with small variations in quality, and same diameter. it's just a matter of pick your poison.
Old May 31, 2010 | 08:27 PM
jeangtd's Avatar
What about aluminium? doesnt it take heat better?
Old May 31, 2010 | 08:48 PM
waltezee's Avatar
Also the Nisei combo (U/Licp & turbo inlet) move the BOV to the driver side by the factory boost controller.
Old Jun 1, 2010 | 06:59 AM
CBRD's Avatar
our ic pipes offer a new turbo outlet and UICP all in alum, it also relocates the bov to the hot pipe making it more effective and losing some weird non efficient plumbing
we also use a 2.75" cold pipe from the IC to the tbody
cb
Old Jun 1, 2010 | 11:49 AM
heavyD's Avatar
Actually aluminum conducts head better than stainless which in the case of piping is probably a negative unless subjected to circulation of cooler air. I prefer stainless myself as polished stainless will maintain it's look longer than polished aluminum and if you have to use T-Bolt clamps you have to be very careful with aluminum piping.
Old Jun 1, 2010 | 12:04 PM
MDH-005's Avatar
I just picked up my new UICP and it cost over $1000 (USD) ...... but it is a future collectors item!
Old Jun 1, 2010 | 07:01 PM
advancEvo27's Avatar
I thought I've read some where that there is problems with aluminium IC piping
Old Jun 2, 2010 | 12:24 PM
armysoldier1073's Avatar
Guys, thanks for all the help. I just placed order with Adam @MAP. got a good deal on the AMS UICP and AMS intake. Thanks again for your help. MAP rocks.
Old Jun 2, 2010 | 12:33 PM
The main problem with aluminum intercooler piping is human error. We all have a tendency to tighten clamps as tight as possible and aluminum piping can easily be over torqued and damaged. Once aluminum is creased, it's almost impossible to get a perfect seal. It's hard not to tighten it down too tight in fear of the couplers blowing off from boost. This is the reason we went with stainless steel piping so the user could tighten the clamps as tight as possible without damaging the piping.
Steel is also way more durable and will last a life time.
Thanks!
Michael
Old Jun 2, 2010 | 12:34 PM
Old Jun 2, 2010 | 02:17 PM
CBRD's Avatar
Michael is right about people crushing pipes with tbolts..
we've seen SS pipes with tbolts and couplers where they were so tight the couplers were torn,
word for the wise, tighter isnt better (let's keep it clean guys)
we use soapy water when we tighten all tbolts and tighten them just over hand tight.
also, Alum was used on any turbocharged race car ive ever driven without durability problems.
to each their own
ETS makes nice pipes, we have nice pipes, AMS has nice pipes, BR has nice pipes lol
cb
Old Jun 2, 2010 | 05:26 PM
monkey_187's Avatar
they also offer 2 piece pipes at a lower price, most people, like me get the one piece.
Old Jun 3, 2010 | 05:47 AM
bremboy's Avatar
Originally Posted by heavyD
Really the most important and overlooked aspect of intercooler piping is the quality of the silicone couplers. IMO this is where the Japanes brands fail the most at as I've had issues with the cheap/thin couplers with Greddy and HKS products. I have the AMS UICP and the couplers are very high quality which is why they seal perfectly without the need for T-bold clamps.
Beg to differ, HKS makes pretty damn good silicone couplers. Zero problems here. I've actually never heard that complaint about HKS piping kits.
Old Jun 7, 2010 | 04:54 AM
MDH-005's Avatar
Originally Posted by ETS Michael
its true....
