my clutch and flywheel at 3700 miles
Old Jul 16, 2010 | 07:59 PM
manofdafam's Avatar
this is how my clutch and flywheel look at 3700 miles on a 2010 gsr. Mitsu wont warranty my synchros because of this
Old Jul 16, 2010 | 08:54 PM
aftershock141's Avatar
Wow...that looks straight molested. Good luck.
Old Jul 17, 2010 | 09:50 PM
ACTman's Avatar
Hard to say. Your pics aren't the best. Generally, a new disc when compressed is about .315" thick and totally worn out if below .25" thick.
Old Jul 18, 2010 | 06:03 AM
RaysEvoX's Avatar
Double post. But while you have the tranny off, I would upgrade it.
Old Jul 18, 2010 | 06:09 AM
milford's Avatar
3700 miles is break in basically...shouldn't you have been taking it easy
meckert's Avatar
Looks like they have you!.. Not sure what the issue is but that clutch has more wear on it then ones I have taken out of my own car with 80k on them-- just so you know that fly wheel with the hot spots--( dark dashes) are a dead give away of the abuse you threw down. If you havent been abusing it in the classical sense then you need to improve your " I can drive a std" skills a lot.
Old Jul 18, 2010 | 06:33 AM
buchnerj's Avatar
Agreed. I really see no way that a clutch got that worn in 3700 miles, unless you were really getting on it...
Old Jul 18, 2010 | 10:03 AM
manofdafam's Avatar
stock disc on the right in this pic compared to mine, its not bad at all
Old Jul 18, 2010 | 10:06 AM
buchnerj's Avatar
The clutch is pretty worn for only 3700 miles though, that is what we are getting at, at that mileage it should be damn near new. Another thing that will be a sign of abuse is the hot spots on the flywheel. You have to get a better picture of it to show the wear patterns on the plate.
Old Jul 18, 2010 | 10:31 AM
ezzey's Avatar
dealer warranty ftl ;o
Warranty is good if you baby your car, in which most cases won't create a problem and you won't have to use any warranty, damn the dealer is so smart, sigh.
Old Jul 18, 2010 | 11:28 AM
murlo26's Avatar
My clutch after 26k miles and over 400wtq looked about the same...you must not be driving right...haha.
Old Jul 18, 2010 | 01:27 PM
manofdafam's Avatar
someone realized that only the other range of the clutch disc is worn. Which isnt normal and if you look at the flywheel it doesnt have any heatspots but does have some glazing only on the outer rim and look like the middle of the flywheel hasnt been touched either
Old Jul 19, 2010 | 01:40 PM
DRAG's Avatar
Doesn't look all that bad to me. What the hell does that have to do with synchros anyway?? You should have seen mine at 4000 TOAST.
Old Jul 19, 2010 | 01:53 PM
JakeTheVIII's Avatar
Doesn't look bad to me either. I simply wouldn't settle for denying warranty work.
Old Jul 19, 2010 | 01:54 PM
High_PSI's Avatar
Like I said on TSE, sue them, just sue them.
