Another "Oh no, white smoke"
Old Aug 9, 2010 | 02:08 PM
meat_EVO's Avatar
Sorry for the nonsense.....
when at idle for about 3 minutes or more, and more often with the AC blasting. The car wil start to PUFF WHITE SMoke out the exhaust. and I believe it smells like coolant.
I have not noticed any other signs, no fluid coming out of the overflow tank under boost and the only smoke under WOT is black (fuel)
small leaky headgasket perhaps? what are your thoughts?
evo x
stock motor, untouched
fpred
25psi most of its life
Old Aug 9, 2010 | 02:12 PM
scorke's Avatar
Who tuned your car?
Scorke
Old Aug 9, 2010 | 02:34 PM
murlo26's Avatar
Originally Posted by scorke
Who tuned your car?
Oh that's right....
You damaged the engine or turbo, or both, congrats.
Scorke
25psi should be no problem on the red or the stock headgasket...however it is possible the stock headgasket wore through a bit I guess, but I think this is the type of problem where you have to pull the head to figure it out.
Old Aug 9, 2010 | 02:39 PM
aronjaskim's Avatar
I bet headgasket or turbo seals.
Old Aug 9, 2010 | 04:19 PM
meat_EVO's Avatar
I tuned my car. Turbo seals would be lovely, much easier and cost less time and money. To fix.
Old Aug 9, 2010 | 04:28 PM
lousEVOxmr's Avatar
might just be humidity in your exhaust , ( after wash or cold mornings )
how many miles?
Old Aug 9, 2010 | 04:44 PM
scorke's Avatar
You do realize that there is a lot more to cylinder pressures than boost?
Boost is only one of the variables that changes the amount of pressure the head, piston, wrist-pin, and headgasket see, and if you tweak the other numbers enough you can pop a headgasket without running a lot of boost...
Scorke
Old Aug 9, 2010 | 05:04 PM
murlo26's Avatar
Scorke
Thanks I didn't know that
I only had that turbo at 33psi on the stock block and the headgasket was perfectly fine at that level.
Old Aug 9, 2010 | 05:12 PM
scorke's Avatar
It's cool, lots of people don't understand that timing play a huge factor in the amount of pressure and therefore torque produced in the cylinder.
You can run 25 psi and 30 degrees of timing vs 30 psi of boost and 5 degrees of timing and make more power at less boost because of these properties.
Scorke
Old Aug 9, 2010 | 07:06 PM
meat_EVO's Avatar
yea my timing is 17* which is pretty much average for the higher power evos in the area. alot of people run alot more.
edit: its 17 from 6k on anyway under WOT load areas
Old Aug 9, 2010 | 07:30 PM
scorke's Avatar
Well go through it systematically, coolant can only come from a couple sources, you're going to be pulling the head and probably the turbo.
Scorke
Old Aug 10, 2010 | 06:54 PM
tephra's Avatar
are you actually using coolant?
Old Aug 11, 2010 | 08:27 AM
chaotichoax's Avatar
I'm with tephra, this would be a sensible thing to check first
Old Aug 11, 2010 | 08:30 AM
agedog2gt's Avatar
check gaskets, and like Tephra said, your coolant. good luck!
Old Aug 11, 2010 | 11:51 AM
Bighec's Avatar
Do a test with one of those dye coolant thingys to see if your head gasket is no good. At least that's what I think it was for. Used to use it all of the time. Been a while though.
W0LF
17
Sep 1, 2017 12:40 PM
Hoojan
Jul 21, 2016 08:36 AM
MaDD-Myke
Jan 29, 2012 09:29 AM
mostafa911
26
Nov 18, 2011 10:08 AM
whiptheevo8
39
May 11, 2011 11:36 PM
