Making the move from stock->FP Black...
Old Sep 1, 2010 | 11:06 AM
RB185AFM's Avatar
You might need bigger injectors.
Old Sep 1, 2010 | 11:22 AM
murlo26's Avatar
Depending on how far he goes, yes he will. 850's max pretty quick with a turbo that large.
Old Sep 1, 2010 | 11:51 AM
HiI'mDustin's Avatar
I would suggest having a daily if you are going to run that turbo. Its not an if you will blow your motor its a when. I am running a red and goign to a 5857 with a built motor in January.
The problem with going with a large turbo and not using it to its full potential is you are getting the lag without the top end. I would go with a red for what you are wanting.
Old Sep 1, 2010 | 04:14 PM
MACKLIN's Avatar
Uploaded with ImageShack.us
just get the black!
Old Sep 1, 2010 | 04:48 PM
mlomker's Avatar
Injectors are too small. FMIC sounds too small. I'm pretty sure that intake uses the stock MAF housing and that will be too small.
Trust me, you don't want the lousy spool + low power because your supporting mods weren't well thought out.
My advice is to wait and let some other people make the expensive mistakes. Put the turbo on the shelf for a few months.
Murlo and I both went through expensive f-ups (Red & BBX, respectively) so this isn't just idle talk.
Old Sep 1, 2010 | 05:12 PM
mchristian's Avatar
I just installed my FP Black on a stock motor with basically every supporting bolt-on possible; Buschur sold me the turbo and a stock WGA and it WOULD NOT HOLD BOOST....do not get a stock 9 or lower spring'd WGA, make sure to get the WGA that comes standard with the Black (25psi).
The car wouldnt build full boost until 6,000 rpm. First pull after installing a higher spring'd (Forge Motorsport) unit we were building full boost around 4300-4500.
Old Sep 1, 2010 | 05:15 PM
MACKLIN's Avatar
that's not for a x though
Old Sep 1, 2010 | 05:16 PM
elusiveGSR's Avatar
thanks for everyones input and thoughts on this. i will hold off on the Black and most likey get the Red now. i dont DD with the X btw. the X is just a weekend car.
mchristian's Avatar
you are correct, my apologizes...standard is 18psi WGA.
Old Sep 1, 2010 | 05:31 PM
MACKLIN's Avatar
what made you decide on the red?
Old Sep 1, 2010 | 09:19 PM
RB185AFM's Avatar
I am guessing the building the engine part, plus needing bigger injectors and at least a 4" intercooler might have played a part.
Old Sep 2, 2010 | 12:45 PM
elusiveGSR's Avatar
Yup.. I just purchased most of my parts recently. I dont find it necessary for me to re-purchase those parts again so soon. Maybe next year I'll get the BLACK, but for now Ill play with the RED..
Old Sep 2, 2010 | 12:48 PM
High_PSI's Avatar
I thought they came with a 25PSI actuator?
Old Sep 2, 2010 | 12:50 PM
murlo26's Avatar
The ones on the Evo 10 do not.
Old Sep 2, 2010 | 03:07 PM
MattyP111's Avatar
if your on a stock motor go with a black. But i heard if ur gonna fully build it go with a hta 86 or 37r sumtin like that. My boy just sold the black and went with hta 86 and says its so much better and alot more fun. Same turbo i have and ext gate and bushur manifold. Just so u have an opinion of someone that owned one
