fp red= a lot of surge???
Old Sep 8, 2010 | 04:46 AM
novaspyder87's Avatar
Hi guys. I installed my FP RED...with 800cc injectors and full bolt-ons no cams....a couple of weeks ago. got tune at IVEY 2 weeks ago.
380 WHP and 367WTQ.....on 91 octane(canadian).
the problem is.... there is supposed to be an ANTI-SURGE on that turbo...
fifth gear ..60mph...hard push.....bang bang bang....until I stopped pushing it.
almost all gear have some surge. the first gear start from 0....is freaking hard...dont go too low in rpms because hes going to die...
I THINK ITS SURGE...MAYBE NOT....thats why im asking.
so....is there a problem with something or its just normal???
Old Sep 8, 2010 | 04:59 AM
tsitalon1's Avatar
Could be surge, ask your tuner to look over your logs and adjust MIVEC accordingly.
Old Sep 8, 2010 | 05:09 AM
ethan169's Avatar
hmmm... What do you mean "bang bang bang until I stopped pushing it?" Was it like a bucking that wouldnt stop until you fully let off the throttle?
Old Sep 8, 2010 | 06:06 AM
yeah a bucking....wap wap wap wap....like missing air or something....it does it a lot...on partail throttle....a little bit less on WOT if your not on the right gear.
if youre in the right gear... theres no surge. its ok....
Old Sep 8, 2010 | 06:15 AM
ethan169's Avatar
Sounds like surging to me. Im not an expert but from what ive seen/experienced surging issues can be both tune related and turbo related. You may have a bit of both. Which RED are you running? The newer 80mm or the older 64mm one? I always heard that the older 64mm ones had a lot of surging issues.
Old Sep 8, 2010 | 06:36 AM
tsitalon1's Avatar
Quoting myself....
That is surge, contact your tuner. Basically the MIVEC maps are to aggressive in lower rpm areas.
Old Sep 8, 2010 | 06:50 AM
HybridKOOP's Avatar
It doesn't sound like surge to me. Surge is just a fluttering normally which is normal with the FP Red.
What you're experiencing sounds more like boost cut. Is it popping and cutting the throttle completely off and on?
Old Sep 8, 2010 | 06:56 AM
ethan169's Avatar
I dont know about boost cut. Boost cut is like hitting a brick wall. In addition if your hitting boost cut at part and low throttle there is another issue on hand. Why would you be over-boosting at part throttle?
The fluttering and the bucking seem to be just variations of compressor surge. Meaning the flutter is just light stuff that if your in a high enough gear you dont feel in the drivetrain. If your in lower gears for your speed you will feel the flutter when you let off as a bucking. At least thats how I experience it.
Old Sep 8, 2010 | 06:59 AM
lousEVOxmr's Avatar
no , its doing like my mr did at partail throttle in 5 or 6 th gear
it surge so much that he has to drop to a lower gear to be able to have power ...
Old Sep 8, 2010 | 07:08 AM
cheez_it33's Avatar
Yeah, I have the same issues with my stock 9 turbo in 5th gear at partial throttle.
Old Sep 8, 2010 | 08:05 AM
Messidona's Avatar
subscribed.. getting my red installed this week, hope to be tuned next week...
Old Sep 8, 2010 | 08:09 AM
Clipse3GT's Avatar
The MIVEC is too aggressive in the exhaust retard MIVEC map or there is too much valve overlap. I would contact IVEY.
Old Sep 8, 2010 | 08:25 AM
TS8's Avatar
TS8
It sounds like what I had until I changed to a Coil On Plug ignition.
It gets more difficult for the stock ignition to fire the mixture as the boost gets higher.
Check out your coils to see if they are OK.
Old Sep 8, 2010 | 08:32 AM
Messidona's Avatar
Arent these tuners supposed to know these things? I am sure when these cars leave the shop there is no surge on the dyno? I guess road driving and dyno driving are two different things more variables etc and driving style.
Old Sep 8, 2010 | 08:35 AM
06MRV8Killer's Avatar
You said this ^, it is definitely possible that it is boost cut, too much load, 5th gear, doing 60mph could cause boost cut.
I don't know about surge or what causes it but if it is surging it is really bad for your turbo apparently...
Did you but the anti-surge for your Red?
Best bet is to make a video documenting the issue and post it up and you will get a better answer to your problem.
