I need clamp sizes for a few things... help?
Hey all, I posted this question on another thread, but thought I would post the actual topic. I'm about to order some atp t-clamps and I wanted to know the size I will need for the turbo inlet (plus the slicone coupler over it) the turbo compressor side (where the intake goes in, plus coupler) and also, I wanted to get the size for where the LICP connects to the throttle body. I'm ready to order these things because I keep getting boost leaks. I've looked at napa and such, but they are MUCH more expensive, and i've heard good things about the ATP clamps.
Please post if you are sure... I don't want to have to order more and wait if possible.
A 3" clamp will work on your throttle body. You'll want 2.75" clamps for the other IC pipe connections and intercooler. The turbo oulet will probably use a 2.25" but I'm guessing on that one. There is no need for using T-bolt clamps on your intake pipe, you can not get a boost leak there; any simple worm-drive clamp is enough to hold the intake on.
