Why does the LICP not do much for the power of these cars?
I mean that crappy little rubber hosing and such.. it just seems like it would pick up more power... but what's the WHP rating like 5 or less? It's not much I do hear that. Does the power increase if you have more mods? Like say i'm pushing 360-370 whp... does it benefit me more then?
the licp doesn't really need replacing because it's a reinforced silicone hose, similar to aftermarket types, whereas the uicp is a mesh hose, prone to expansion. reinforced silicone hoses supposedly are able to hold up to 50psi of boost, give or take. if you're going for high boost applications though, i'd just replace it regardless.
this.
I mean i've seen multiple people say that the LICP for the X was very well made... i'm just wondering why none of these top companies have been able to improve on the design of it.
i upgraded mine with a "hell why not" mentality as well; i was upgrading the uicp, ic, intake, widemouth o2...so damn, might as well!
This is confusing to me. Quote from the "modding for dummies" thread. I have about 24 hours worth of Evo modification knowledge under my belt, but don't understand why the thread says replace licp and this thread says don't. I must be missing something.
Intercooler Piping (UICP/LICP):
The upper intercooler piping (UICP) isn't going to do much in terms of gains but it will limit you to a stock flanged DV/BOV. The lower intercooler pipe is a great mod. It will improve spool up. Reason being, the stock LICP tapers towards the turbo and has unnecessary bends.
- UICP: Not really a necessary mod unless you need a different flange or you are using a mini battery and have the room to use a shorter route UCIP.
- LICP: Definitely a great mod, you'll see HP/TQ gains as well as quicker spool up.
- It's not a bad idea to upgrade the stock pipe couplings. They tend to expand under boost.
https://www.evolutionm.net/forums/ev...g-dummies.html
