Why does the LICP not do much for the power of these cars?
Old Oct 13, 2010 | 10:18 AM
gsrboi80's Avatar
Originally Posted by cbr1000
This is confusing to me. Quote from the "modding for dummies" thread. I have about 24 hours worth of Evo modification knowledge under my belt, but don't understand why the thread says replace licp and this thread says don't. I must be missing something.
Intercooler Piping (UICP/LICP):
The upper intercooler piping (UICP) isn't going to do much in terms of gains but it will limit you to a stock flanged DV/BOV. The lower intercooler pipe is a great mod. It will improve spool up. Reason being, the stock LICP tapers towards the turbo and has unnecessary bends.
- UICP: Not really a necessary mod unless you need a different flange or you are using a mini battery and have the room to use a shorter route UCIP.
- LICP: Definitely a great mod, you'll see HP/TQ gains as well as quicker spool up.
- It's not a bad idea to upgrade the stock pipe couplings. They tend to expand under boost.
https://www.evolutionm.net/forums/ev...g-dummies.html
What you are reading is for the CT9A evos. VII/VIII/IX. Same rules do not apply to the X
Old Oct 13, 2010 | 05:25 PM
cbr1000's Avatar
geez, you're right.
I got a new car on order so I'm trying to figure out what mods to do, I figured I would use the search to see what route to go.... I didn't see that it was in the evo 9 section.
crap, that link was very helpful... if I had a 9.
well, back to more searching... I thought I had a couple items figured out, back to square 1.
Old Oct 14, 2010 | 07:39 AM
OBP's Avatar
OBP
Originally Posted by endGameXIII
there's really nothing to improve upon. if you look at all the licp's, they're all routed in the same fashion. the only difference is some would reroute the bov pipe. otherwise, the silicone is very beefy and even high hp apps usually don't upgrade it, and only upgrades to pipe with a "hell why not" mentality. the only potential benefit i see with pipes is that they eliminate that small air pocket that the silicone hose has before the throttle body, but that would yield maybe what, negligible throttle response.
i upgraded mine with a "hell why not" mentality as well; i was upgrading the uicp, ic, intake, widemouth o2...so damn, might as well!
Well said.
When thinking about power gains is the original design flawed? Is it bottle necked?
The stock LICP is pretty stout where as the UICP bottle necks and is made of mesh on that one section.
Lightsaber
May 28, 2016 05:57 PM
David Buschur
156
May 17, 2008 04:05 PM
erioshi
14
Apr 13, 2008 10:34 AM
forbidden color
Apr 15, 2006 06:12 AM
chapter8
23
Jan 7, 2005 09:33 PM
