Possible to blow the off of the fuel pump?
Old Oct 9, 2010 | 08:13 AM
Methodical4u's Avatar
Ok, as some of you may know, i've had some idling issues for about a month or so... changed plugs, checked for leaks, double zip tied the line to the manifold and every other vac line, pretty much everything that can be checked, was and has either been fixed, or there was nothing wrong with it to begin with... so I got to wondering from the other guys post... is it possible to blow the line off of the fuel pump? I've never had the fuel pump out and never even seen it, so I have no idea how it's put on, but could this be a reason for a bit of a rough idle? It's not extremely rough, but it is somewhat. Any ideas?
Old Oct 9, 2010 | 09:38 AM
bbbwrx's Avatar
If the line was off the fuel pump the car would not run at all.
EDIT: I should clarify. The fuel line not a vacuum line. There is no vacuum line running to the fuel pump.
Old Oct 9, 2010 | 09:42 AM
05VIII's Avatar
Are you asking if the fuel line can pop off of the fuel pump??? How would you get fuel if it did?
Sometimes it helps to think before you act.
What's the background on the car? Mods? Tuned?
Old Oct 9, 2010 | 04:57 PM
TBE, UICP, 3 PORT, CAI, did have a Perrin BOV, now Synapse (if they ever get it right and get it back to me) but those mods, was tuned by Mellon, worked fine for a few weeks and then it started having this idle problem.
Old Oct 9, 2010 | 06:50 PM
lowkey's Avatar
Registered User
You switched to a Mellon tune because of their superior support. What do they say?
Old Oct 9, 2010 | 07:05 PM
I switched from Mellon to 4ws... who told me it could be a leak somewhere, or it could also just be that when you add more mods the car isn't always perfectly smooth... oh yeah I have an ETS 4" IC too.
Old Oct 9, 2010 | 07:10 PM
let me add that it doesn't affect the way the car drives in any way, it's just sort of annoying... I guess I always expect it to idle exactly like it did from the factory.
Old Oct 9, 2010 | 08:11 PM
itznoraa's Avatar
do you have an AFR gauge? cause sometimes my car gets idle problems when the car goes too rich then the car compensates for it and leans it out, but gets too lean and richens it and becomes too rich therefore i get a loopy idle. But for me, the problem usually goes away with a blip of the throttle.
Old Oct 9, 2010 | 10:27 PM
well if I hit the throttle everthing is good. The tuner looked at it and said it's fine and that the logs look good so there is not cause for alarm. I think it's just some of the mods I have put on the car that have caused it to be like that...nothing has stopped it, so o well... not going to worry about it anymore.
Old Oct 10, 2010 | 07:57 AM
aftershock141's Avatar
What kind of idle issues are you having?
Old Oct 10, 2010 | 08:21 AM
h0ndab0yb3b0's Avatar
my friends car did the same thing he never found out so he just put cams in it to help his ocd...so he dont gotta worry bout the roughness lol
kaj
May 27, 2015 06:11 PM
EvoAirRick
Apr 25, 2013 05:50 AM
Graphic
Jun 22, 2012 09:37 AM
sykou
Lancer Troubleshooting
Aug 17, 2008 11:44 AM
ultra721
May 31, 2007 11:55 PM
