Those that installed there own FP Black/Red
Old Nov 5, 2010 | 08:15 AM
twinturbogreg's Avatar
I'm getting the FP Black soon and I'm wondering if the install is as straight forward as re-installing the stock turbo... I know for the Black there are different oil lines... but other than those is there any heat shield trimming or any other modifications that has to be done to make this turbo fit? I'm just preparing myself for the install. Thanks!
Old Nov 5, 2010 | 08:24 AM
fqjdmct9a's Avatar
I dont know about a evo X but nope pretty much just swapping turbos. My friend and I put his red on his 8 a few months ago.
Old Nov 5, 2010 | 08:30 AM
NotAnEvoOwner's Avatar
Still stock frame, so if you've pulled the turbo before, you'll be fine.
Old Nov 5, 2010 | 01:09 PM
EvoX2NR's Avatar
minus the oil line kit it will be just like if you reinstalled your stock turbo
Old Nov 5, 2010 | 01:13 PM
Brewster's Avatar
the bolt under the turbo is a pita, just get ready for bloody knuckles and cuss words.
Old Nov 5, 2010 | 01:25 PM
EvoX2NR's Avatar
once you remove the rest of the heatshield bolts move the heatshiled to get that one PITA started
Old Nov 5, 2010 | 09:29 PM
BEISSEN's Avatar
Unless you have a built motor and head the black is going to be to big on a DD and you more.then likely wont get into the sweet spot of the black which is above 30psi. There are 8 & 9 guys downgradeing to a red as its to much for a stock motor. Im not familiar with the X so maybe yours are better.
asu11
Jul 30, 2015 04:37 PM
Wiznaz
Apr 21, 2015 07:01 PM
06rallyred
Aug 25, 2014 07:25 PM
criptballer
27
May 31, 2014 07:40 PM
veszett
30
Apr 6, 2011 09:10 AM
