Is it safe to go 8k rpm with stock internals?
I definitely would be worried if internals are bone stock and and rev limiter is past 7,800rpm. I don't think the hole that would appear on your block will help the process of forced induction at all...
Interesting he did hold your car out to 8k, bluegsr. I dont know, in my opinion for you i wouldn't hold it out to 8k. Your really not "making" anymore power after 6800rpms your just dropping power and to me that seems pointless to hold it out at the risk of engine damage. I'd keep it to 7k.
The problem isn't the cams, it is your valves and springs. At 8000 you could snap a spring and float a valve, especially with aftermarket cams having a higher lift and duration than stock cams. They are just more aggressive on the valvetrain than the stock cams, and that added with a higher rev could cause serious problems. Build the head if you plan to rev that high.
Best advice here.
Don't listen to misinfo. We have been tuning evo X since they came out and we have done so many, if there was a problem revving to 7800-7950 on stock cams/springs we would have found that long ago. I say there is no issue with this.
On the matter of upgraded cams designed for higher spring pressure I would say no, do as the cam manufacturer recommends and install the valvetrain components necessary.
STOCK REV LIMIT IS 7600.
Sean
Sean
Sean
Sean
214b w/ the kelford springs, stock retainers. 8k is my rev limit, though i rarely reach it. And, in interest of saving my rods, I short shift like a **** on the track when running all out, shifting around 7200. So it costs me a few seconds a lap.... better than having an extra hole in my block and a fiance that wants to kill me for spending 10k on my engine when I told her itd only be 5 :-)
Sean
Sean
