Unresolved Situation Update
what are you using for boost control? stock solenoids? mbc? 3port BCS?
to me it sounds like your wastegate is staying shut longer than it should/opening slower than it should. this would explain your overboosting. while the fluttering is normal (I experience it daily), my car does not buck. if your wastegate was still shut while you were relieving the charge pressure, you would still be building some boost, and this could explain the violent bucking.
answer my initial question and we can go from there. do you have the ability to log via evoscan?
Its hard to ignore when it happens in 3rd 4th and 5th gear, and basically bucks the car back and fourth rapidly for about 2 seconds... I guess I'll try the BOV first and go from there... Remind me because I havent worked on my car in a while, do I need to tune with a BOV?
I don't think Its a boost leak, It only happens about 3500 RPM, under full throttle no problems with the idle, just an overboost occasionally, which I presume is related to the BOV having a premature release of the air.
UPDATE: So last night I was driving home and cruising about 65 mph at about 3400 rpm, all of the sudden the whole car stuttered and then my gas pedal went dead and the ASC SERVICE REQUIRED picture appeared on the middle of the display. I couldn't keep the car going and had to pull over, once it reached idle the rpms were jumping from 500-2000 erratically. I shut the car off, waited for 10 seconds, restarted it and all was fine. Anyone know wtf could be going on? I just got my car back about 8 months ago from a big collision on the passenger front side and have had nothing but problems with the vehicle since.
I am no expert but the 500-2000 rpm cycling sounds like a MAF on it's way out. Also, could possibly by why it flutters etc as it's measuring the air wrong (just an assumption). Maybe it's still working well enough to not warrant a SEL to pop up as well. Anyone else that can chime in?
REPLACED BOV with new stock BOV and all issues have resolved, vehicle no longer overboosts, no stuttering, and almost completely silent during release of pressure.
