BOV/Engine issue
Old Nov 25, 2010 | 09:02 AM
philamthebest's Avatar
BOV/Engine issue
hey guys, a quick question?
I installed a cold air intake and it works great for the most part. Sometime when i let of the gas slightly the BOV flutters and then the entire car shudders, and i have to accelerate for it to stop. Do you guys have any clue on what this may be?
Thanks
Old Nov 25, 2010 | 09:13 AM
max4rw's Avatar
more info: what kind of bov/dv r u using? stock or aftermarket? you may have to get the car tuned to have it run properly after installing the intake
Old Nov 25, 2010 | 09:20 AM
Evojj25's Avatar
i agree with max, you might have to get the car tuned or adjust the screw on top of the bov. i have aps bov that was fluttering as well until i adjust the screw so it wont flutter.
Old Nov 25, 2010 | 03:43 PM
I have a stock BOV. So adjust the screw? Was your entire care shuddering?
Old Nov 25, 2010 | 06:47 PM
►EvolutionX◄'s Avatar
Just posted relatively the same post here last night, do you get an overboost issue when going WOT in 5th gear? -- I have the shuddering issue
Old Nov 25, 2010 | 10:17 PM
Jookies's Avatar
I have the whole car stutter, only from being in 5th on a hill at too low of an rpm. I know a few others who have the same issue. I thinks it's normal, and to get rid of it, just downshift for hills.
Old Nov 25, 2010 | 10:45 PM
Is there a fix for this issue? And now you mention it, it is in 5th gear...
Old Nov 26, 2010 | 09:12 AM
Jookies's Avatar
Yeah it seems pretty common, you don't hear it until you have an open intake, but I've felt the stutter before I had my intake on.
Old Nov 26, 2010 | 09:59 AM
RallySport Direct's Avatar
Silver Sponsor
This is a issue that is quite common on many turbo cars when power levels are increased over stock.
A inexpensive solution for this is to install a larger ID vacuum line that runs to the blow off valve. Should eliminate the issue you are having.
Old Nov 26, 2010 | 10:54 AM
Jookies's Avatar
Is it damaging? Or just annoying?
Also, the only reason I don't think this is the case is that before I had my intake in (my only mod) I could still feel the stutter, though I wouldn't hear it.
Old Nov 26, 2010 | 04:03 PM
Yeah i too worry it's damaging....
xsynthx
Jul 17, 2009 09:14 AM
importjake00
May 9, 2008 04:50 PM
kungfugirl
Lancer Aftermarket Forced Induction Tech
11
May 6, 2007 11:06 AM
highvelocitykid
Sep 8, 2006 03:07 AM
evodave
10
Feb 12, 2005 07:16 PM
