Competition: Stage 5 4 Pad Ceramic Clutch Kit
Old Feb 28, 2011 | 09:30 PM
bluegsr's Avatar
How do you guys feel about this clutch matted with the FP-Black on stock block 93 octane? too much clutch? i plan on abusing it on the strip but i still wanna daily drive my car. discuss
Old Mar 1, 2011 | 08:48 PM
chetrickerman's Avatar
Veteran: Army
im going to go with the stage 4 sprung hub.
i dont see why you cant go with the stage 5, just a little more chatter, and harsher engaugement
Old Mar 4, 2011 | 07:04 PM
Veteran: Army
I pm'ed MAP and they said the both the stage 4 and 5 are awesome clutches.
Old Mar 4, 2011 | 08:13 PM
Wht9er's Avatar
hope your doing diff pins and some sort of clutch master cylinder upgrade as well...thats if you havnt already.
Old Mar 4, 2011 | 08:46 PM
Kracka's Avatar
Comp clutches won't put a whole lot more strain on the CMC than the stock clutch will so my guess is the plastic stocker will be fine.
Old Mar 4, 2011 | 08:52 PM
Veteran: Army
where do you get that from?
the stage 4 is a 250% increase in holding over stock.
http://www.maperformance.com/competi...5107-1620.html
you definitely need to upgrade the CMC
Old Apr 23, 2011 | 03:25 PM
Deepseadiver's Avatar
I'm a bit shocked at MAP for not bringing this up when I ordered my clutch last week. I went with the stage 4.
Any reviews of this clutch?
Old Apr 23, 2011 | 03:30 PM
Kracka's Avatar
The rated holding capacity has nothing to do with the strain put on the CMC, what matters is the weight (clamping force) of the pressure plate and the geometry used to created that clamping force. The Competition Stage 4 gets it's holding capacity from the friction material and 6-puck design, not an ultra-heavy pressure plate. The Comp stage 2-4 clutches all use the same pressure plate; not sure about the stage 5 but I'm guessing it's also the same. I had the stage 3 in my IX (actually prototyped it for them using three different variations). It will be no harder on your stock CMC than offerings from Clutch Masters, Spec, WORKS, etc.
To the OP - the 4-puck is going to be a very grabby clutch for daily-driver duty, but if you get it at least opt for the sprung hub. I'm tempted to suggest you get the sprung 6-puck instead (the stage 4 isn't too bad of a clutch at all for street use), but don't want to be responsible for giving you bad advice if it were to slip
JorgeAvila
Jan 13, 2015 02:02 PM
GSX 911
Sep 23, 2013 05:43 AM
swangdog
15
Jan 4, 2013 12:12 PM
bumblebee04
Apr 4, 2011 10:02 AM
