Hks racing suction intake
Old Mar 26, 2011 | 08:32 AM
dgarcia41982's Avatar
Can someone tell me why this intake is so expensive? Is it that special that its nearly double the price of the other brands
Old Mar 26, 2011 | 08:43 AM
Nauticabri's Avatar
HKS stuff is usually quite pricey. That isnt to say there products arent good, but, definitely can be pricey.
Old Mar 27, 2011 | 04:16 AM
MarkM's Avatar
Love mine, works extremely well, I've now put it in a kansai box with cold air feed...hks ftw
Old Mar 27, 2011 | 03:11 PM
Still is there anything about it that makes it stand apart from the rest? Just wondering because it was recommended to me. But through my research I have not found anything concrete to see it a worthwhile buy.
Old Mar 27, 2011 | 03:17 PM
MarkM's Avatar
It's 3" All the way from the filter head and bolts right onto the turbo, no silicone reducer like most others. Looks pimP too lmao
Old Mar 28, 2011 | 03:52 AM
Thanks
Old Mar 28, 2011 | 05:38 AM
blk-majik's Avatar
no reducer on a 3" pipe feeding into a 2.5" turbo inlet? that'll cause a ****load of turbulence and reduce flow.
Old Mar 28, 2011 | 09:03 AM
MarkM's Avatar
Original is 3" reducing from 2.5" from the intake
Old Mar 29, 2011 | 11:31 AM
blk-majik's Avatar
the stock turbo inlet is not 3". It's at most 2.5", but I think it's actually 2.25". I think the inducer itself is 56mm. The FP Red inlet isn't even 3" (although they do sell a 3" inlet adapter for the reds iirc).
like i said, if the intake is a full 3" to the turbo compressor, then it's a horrible design.
Are you sure it 'bolts' to the turbo? did you install it yourself? An intake that replaces the turbo inlet seems a little odd since it would only work on the factory turbo.
germanmike954
Jan 9, 2017 12:21 PM
evo8vz
Dec 16, 2016 08:27 AM
Tribal
May 12, 2016 09:05 AM
hydro334
Apr 2, 2016 11:22 AM
StreetLethal
Feb 2, 2016 04:12 PM
