Magnus Evo IX CMC conversion or SSP CMC?
Old Apr 22, 2011 | 02:23 AM
tjac357's Avatar
Originally Posted by vastevo
and my SSP v3 CMC just pooped on me on the way home from work. Glad I was close enough that I didnt need a tow.
EDIT: After talking to SSP, it is impossible for V3s to fail. This pretty much tells me I do have a V2, which would make it #3. Time to order the magnus.
Impossible is nothing.
Old May 2, 2011 | 10:12 AM
L888Apex's Avatar
Just installed the the ACT HDSS, ACT Flywheel, and MAGNUS CMC this past weekend and the whole thing was a ****ING NIGHTMARE. Me and my friend are fairly good with mechanical work, but installing those three things were the by far the worst things I have ever installed. Part of it was due to not having the best tools but even then it was still bad. To grind/drill the little "nubs" off of firewall to put the Evo IX CMC/Magnus Adapter on took a solid 2hrs alone because of the small air grinder we were using (tight space so couldn't fit something big ). Getting the tranny off and back on was PITA because we didn't have a tranny jack and we were working on the ground (jack stands). I don't think I will ever install one of those again >_< The whole thing took a total of about 16hrs, not including food breaks and multiple energy drink runs. Without the magnus adapter/evo IX cmc we would have been done in about 12hrs.
Old May 2, 2011 | 12:35 PM
MarkM's Avatar
^^^ no need to grind off the studs, bit of a wiggle from the inside and they break off saving a lot of mess and language lmao
Old May 2, 2011 | 05:46 PM
L888Apex's Avatar
We put a flat head on them and hammered and they WOULD NOT budge.
Old May 3, 2011 | 02:08 AM
tjac357's Avatar
just be glad you won't have to worry about do it again now! congrats on getting it done man!!
Old May 3, 2011 | 03:20 AM
MarkM's Avatar
From the inside? 9mm socket with a small extension over the end, couple of wiggled, they come out.....
Old May 3, 2011 | 07:51 AM
L888Apex's Avatar
Yes from the inside. We put a screwdriver between the threads on the stud and gave it a few nice hits with a hammer and it didn't move. Then we tried from the outside and it was a no go
Old May 3, 2011 | 07:52 AM
L888Apex's Avatar
Yeah lol never doing that again............well not for the amount I got paid to do it at least
Old May 5, 2011 | 05:49 AM
01CBR929's Avatar
I'm planning on getting the Magnus, I think my cmc is on borrowed time with my exedy triple disk clutch.
Old May 5, 2011 | 12:42 PM
WarmMilk's Avatar
i have over 2k and a lapping day on my magnus now, still works great
Old May 14, 2011 | 02:24 PM
Deepseadiver's Avatar
What dose it feel like when the CMC goes? I just installed my new clutch and flywheel and think I have air in the clutch line or the CMC went on the first try. The clutch pedel stays on the floor.
Old May 15, 2011 | 12:01 PM
MarkM's Avatar
I had a bang, then pedal to the floor. If you reach in from the engine bay and grab the plastic cmc it will move around
Old May 15, 2011 | 05:17 PM
JimGVT's Avatar
Might just be air in the line. I just replaced my brake fluid today, and it was a PITA to bleed the clutch. Much more so that last time, not sure why. Had air in the slave cylinder and had to play with it quite a while to get it all out. Pedal would just go to the floor and wasn't able to get the air out by just pumping the pedal - actuating the slave cylinder finally worked.
Old May 15, 2011 | 06:31 PM
LapDance's Avatar
Which one would you choose if you had to upgrade your clutch? Are there any other options besides those two? I will be tearing down my car here within the next week or so and I decided to "upgrade" but after reading so many stories of both failing I was wondering what everyone else would choose and why........
Any opinions, comments, or suggestions would be greatly appreciated to help me and those that are in the same boat.
-TIA
I've heard better things about magnus. what clutch are you equipped with? Oh and whats up with the norcal evo meets hit me up =o
Old May 16, 2011 | 07:53 AM
01CBR929's Avatar
I started my install on the Magnus yesterday, hoping to finish it tonight after work. Got the nuns off so Im hoping its down hill. Just a matter of getting an extra person there to help tighten the mc bolts.
