2.0, 2.3, 2.4 can't decide? :(
Old May 11, 2011 | 10:38 AM
Kevin Knight's Avatar
Currently in middle of a motor build and i can't decide which route to go. One day it's a 2.3 next I want a 2.0. Well times running out and i have to pick. Plan on running a fp black on pump gas after build. But I know as time goes on hp goals go
Up. IbDon't wanna be kicking my self in the but down the road for getting the wrong build. Any feed back or advice would be great.
Old May 11, 2011 | 10:48 AM
armysoldier1073's Avatar
Not sure you realized this...... you posted in the X forums.
Old May 11, 2011 | 11:26 AM
valvetap's Avatar
Personaly I did alot of research because I was undecided myself. But, after talking with a couple good friends, I deciced to go with a 2.1 (destroked 2.4). It utilizes a 2.4 block with a 2.0 crank, 156mm rods and 2.4 (87mm) pistons. This setup offers a good rod ratio due to the destroke. It also enables you to rev that ***** to 10k with no problem. There is quite a bit of info on it on the site. Any questions, just call Nate at MAP. He gave tons of helpful advice and killer deals.
