gtx3071r - dyno?
From what I understand: Before Garrett Released the GTX Turbos, ATP used Garrett GTX parts and possibly some of their own to Create the turbo. Maybe all parts were Garrett, maybe they werent? I can imagine they could have used the older bolt on GT turbo parts and machine the comp housing to except, idk just a guess.
Ronnie
Just so you know all of the GTX Evo X turbos below are 100% Garret, nothing on them is from ATP. ATP just sells them.
http://www.atpturbo.com/mm5/merchant...gory_Code=VEVO
ATP made stock frame Garret turbos for the older evos, not the X.
Actually , Before Garrett came out with the kit, ATP built them.
can you provide a source on the full garrett one that is evo x bolt on?
*edit -looking for some garrett part numbers to order through honeywell employee and get me a discount
R18eclipse, any updates on GTX3071R
im curious about the results coz im totally confused, between GTX3071R & fp green ..
n is it laggy than fp green?, n howz the spooling comparing with fp green?
im aiming 400hp since i have OEM clutch
i own X-SST, so no idea if it will work with it well !
n these are my mods:
Ultimate Racing CB
AMS TP
AMS widemouth DP
K&N typhoon intake
Blitz BOV VENTURI DRIVE
ETS FMIC 3"
ETS UICP + LICP
Areomotive 340 fuel pump
Deatsch injectors 850CC
Cosworth cams - on plan, didn't buy it yet
Ultimate Racing CB
AMS TP
AMS widemouth DP
K&N typhoon intake
ETS FMIC 3"
ETS UICP + LICP
