Stuttering WOT
Old Nov 11, 2012 | 07:59 PM
JReid's Avatar
Originally Posted by BadKarmaCreepin
bringing this back since i'm running into a similar problem - where do i find the relay, and is there anyway to confirm that is problem?
I posted your info needed in the other thread you posted. Boom.
Old Nov 16, 2012 | 10:54 AM
Apex_Kurt's Avatar
After reading this post, I'm really thinking I need to change my spark plugs, because my car doesn't stutter at WOT, but it stutters at freeway cruising speeds every now and then. It almost feels like fuel cut but I'm not sure, I've never felt anything like it in any of my other cars.
Old Nov 20, 2012 | 09:42 AM
evo_xtc2011's Avatar
Are you running e85? e85 can clog up your injectors and cause your evo to run lean and stutter, if that is the case, have them cleaned every 5k miles.
Old Nov 20, 2012 | 09:58 AM
Old Nov 20, 2012 | 11:24 AM
gabesir's Avatar
Everyone always forgets.... Dude is your stupid A$$ fuel pump relay..
Link
Another Link
Old Nov 21, 2012 | 06:09 AM
Foolproof's Avatar
Mine does the same thing. I had a GFB BOV and it was really bad in 5th at 65-80. I put the stock one back on and its better now but still get a stutter every now and then. Guess I need to check my plugs.
Old Nov 21, 2012 | 06:26 AM
Apex_Kurt's Avatar
I changed that relay like two weeks after I bought my car haha. First thing I purchased
Old Jun 14, 2013 | 04:57 PM
incandescent's Avatar
Revivng to see if OP found resolution as I am in the same boat, replaced the FPR to the new(er) green one and its still same thing
Old Jun 14, 2013 | 05:13 PM
BadKarmaCreepin's Avatar
Wink
Not really. What fixed it is it got warmer. I think the boost was spiking, causing the ungodly thud sound.. That, and maybe the v201 map. The FPR swap helped a little initially, but then it resurfaced. If you're in warm weather, I have no idea what to tell you. Log it, look for a lean A/F, watch the boost. The v400 peaks at 29, so it already sounds ridiculously high, but it shouldn't be more than that. But as for a specific cause, if it gets cold again and it starts up, then the cold messing with the A/F will have to be the gremlin. I pound on the car daily, and since it's been above 45, all is good. Let me know if you find something different.
Best, Dan
Koroshiya
34
Oct 20, 2017 07:15 AM
Heirthos
May 13, 2017 12:49 AM
Mikey15
Mar 26, 2013 12:36 PM
vnguyenl
21
May 26, 2012 03:13 PM
crazy j type-X
Feb 22, 2012 08:22 PM
