Evo x downpipe installation
Old Oct 3, 2011 | 09:11 AM
Jookies's Avatar
With the right tools, (lift, tool extentions), and experience about how long should it take to put a downpipe in?
Thanks!
Old Oct 3, 2011 | 09:50 AM
armysoldier1073's Avatar
is it the 02 housing eliminator, or from the o2 housing back... they are different. the o2 housing back might take like 20 min, use pb blaster on speing bolts and extentions. the o2 eliminator takes anywhere from 4-? hours easier if you have a lift available. hard part is getting the drivers side facing bolt. but wait till it cools down and pb blaster all bolts that you can. take your time so as not to strip or break bolts off..... then a crappy day just turned into a ****ty longer day. Map and AMS have a how to on their DP.
Old Oct 3, 2011 | 09:59 AM
Jookies's Avatar
It's just a normal O2 housing back ( not a widemouth or anything like that) So shouldn't take that long huh? awesome.
Old Oct 3, 2011 | 04:38 PM
does it replace the o2 housing?.... if not then it is just 4 spring bolts. easy job.
Old Oct 3, 2011 | 04:44 PM
AJsGenerX's Avatar
15 minutes Rob
KevinD
Mar 29, 2009 12:09 PM
chapscalyx
Mar 13, 2009 07:43 AM
tony_b
Mar 11, 2009 07:24 PM
Blackevoate
10
Feb 17, 2007 02:07 PM
Viciouz
Lancer Engine Tech
40
Apr 13, 2004 06:24 PM
