Header & Downpipe Installation
Old Apr 11, 2004 | 06:02 PM
Viciouz's Avatar
Question Header & Downpipe Installation
Hey guys, I was wondering how hard it is to put in a Downpipe and a Header? What tools do I need? What should I watch out for? How should I go about doing it? How do I extend the 02 sensor if need be? I ran a search on this but couldn't find any information that would help. So I need your help guys.
Old Apr 12, 2004 | 03:42 PM
blaze_125's Avatar
Gotta bump a few notches... cause I gotta know as well
Old Apr 12, 2004 | 04:06 PM
Viciouz's Avatar
c'mon doesn't anyone know? (Bump)
Old Apr 12, 2004 | 04:21 PM
fkrzo's Avatar
I'll save you a search. The only problem most of us had is the lower left nut on the exhaust manifold. I used the turn the wrench a little at a time method. Some say you can use a wobble adapter, but I tried it and it would not fit. Others notch the power steering pump bracket to fit the socket in. And some say to pull off the timming belt cover and bend the thin metal out of the way to fit a wrench. The O2 wire should reach. Tools you need are wrenchs, sockets, extensions and a ratchet. 12,14,15, and 17 MM should be about it. Maybe a flathead screwdriver.
Old Apr 12, 2004 | 04:27 PM
Viciouz's Avatar
so all i got to do is lift the car, make sure its high enough and unbolt and bolt back on? What if I have to extend the o2 wire? Do I even have to have the o2 wire in?
Old Apr 12, 2004 | 04:42 PM
Therios's Avatar
Registered User
You dont need to raise the car at all, when I put my headers in there was just enough ground clearence to fit under the car to manuever a wrench in order to get at the header/downpipe bolts. You should go aheaed and screw the o2 sensor back into the new header, you really dont want loose wires underyour hood . lemme know if you need anymore info
Old Apr 12, 2004 | 04:50 PM
Viciouz's Avatar
well... my header came with a downpipe, i am a little skeptical bout fitting under my car to put in the downpipe
Old Apr 12, 2004 | 04:58 PM
Therios's Avatar
Registered User
you can always unclip the plastic guards for better access but if you have a convinient way to lift the car other than the jack that came with the car, i personally didnt trust it
Old Apr 12, 2004 | 05:01 PM
blaze_125's Avatar
I am a little bit too. Cause I started installing mine last friday, and I had to stop when I got to the point where I needed to install the downpipe. You need to be able to take off the 2 screws that connect that downpipe to the rest of the exhaust system under the car. I ended up putting everything back on, and I'm now waiting for this upcoming weekend to get a hold of a friend who has a hoist in his garage (lucky bastard ).
And on top of that... those screws are on there pretty tight. I ended up breaking a socket on 1 of them. It was not the best socket ever but still...
Old Apr 12, 2004 | 05:05 PM
IILANCERII02's Avatar
From someone who isnt that knowledgeable with cars - it wasnt that bad. Like everyone else said u just gotta watch out for that lower left nut, everything else, i guess also for the downpipe connection to the rest of the exhaust is kind of a ***** too, but its pretty easy, and if your strong and have the right tools shouldnt take u too much tmie at all.
Old Apr 12, 2004 | 05:09 PM
blaze_125's Avatar
I know we should not work under a car that stands on jack. But is it safe to use those
1 of those under each side?
Old Apr 12, 2004 | 05:12 PM
Therios's Avatar
Registered User
personally i dont trust those, i'd say you might as well take it to someone who has a profesiional lift
Old Apr 12, 2004 | 05:15 PM
Viciouz's Avatar
yah... thats wat i was thinking blaze, is it safe to use jacks like that? or should i find someone with a lift? cuz I know for shure that i can't get under my car to loosen the bolts around the downpipe
Old Apr 12, 2004 | 05:16 PM
Therios's Avatar
Registered User
see heres the problem, when i was unscrewing the bolts that connected the stock header and downpipe, I was moving the whole car with the torque wrench, now imagine a car moving like that on jacks, these bolts are a *****, you will need some upperbody strength to crack all the caked on rust so there will be a decent amount of movement. Best to leave it on the ground and swivel yourself into place of get the pro lift like I said b4
Viciouz's Avatar
*SIGH* all the mechanics are a ***** around here... they keep charging me like 400 + dollars jus cuz it requires the removal of the cat.
