Weird Drivetrain Problem !
Old Nov 20, 2011 | 12:32 AM
m7mad.a's Avatar
After installing the following parts:
MAP Aluminum Flywheel
Spec Stage 3+ Clutch
Buschur Diff Pins
Driveshaft Carrier Bushings
The gear is very smooth when upshifting, but when downshifting it becomes a bit hard, however when I press the accel pedal a bit it will become very smooth to downshift. I have been told that the gear cables may need adjustments?
What could be the problem?
