Need info for 15k service
Old Dec 12, 2011 | 11:47 AM
EvoX-11's Avatar
I will be getting my transmission fluid changed with red line cocktail, rear diff and transfer case with OEM mitsu fluid.
Is there anything that I need to pay close attention to? Like is bleeding required?
I really dont want to have issues with my rear diff or transfer case after fluids are changed.
Some members' transfer case started to whine after the flush...
Please share your .02
Old Dec 12, 2011 | 12:30 PM
rcheung's Avatar
The only time i heard of transfer case whining after fluid change is either if its underfilled and there was a lubrication issue or it was overfilled and fluid came out of the breather.
Old Dec 12, 2011 | 12:31 PM
Kracka's Avatar
Agreed with replacing those fluids at 15k miles; nothing to bleed, just drain/refill. Be sure both rear diff fluids are done.
Old Dec 12, 2011 | 04:56 PM
EvoX-11's Avatar
Awesome!
What you mean by both rear diff fluids?
Old Dec 12, 2011 | 04:58 PM
Kracka's Avatar
Diaqueen 90W LSD and Diamond ATF SP3, two separate drain and fill bolts. The transfer case uses just the Diaqueen 90W LSD.
Old Dec 12, 2011 | 05:03 PM
EvoX-11's Avatar
Oh crap! I dont think I bought the Diamond ATF SP3 damn it... I didnt even know there were 2 rear dif fluids existed.
Old Dec 12, 2011 | 05:14 PM
EvoX-11's Avatar
Is this the one you are talking about?
http://www.maperformance.com/mitsubi...ch1zc1x05.html
And all I need is a single qt right?
Old Dec 12, 2011 | 05:27 PM
dek0026's Avatar
yes a single quart will be more than enough for the diff. it only takes like .4 of a quart.
if you're doing a full drain and fill of the acd/ayc fluid, it's 6 quarts and then bleeding is required.
Old Dec 12, 2011 | 06:38 PM
EvoX-11's Avatar
I dont think acd/ayc fluid flush it required for 15k service, right?
Old Dec 12, 2011 | 07:28 PM
dek0026's Avatar
Correct. Without looking at the manual, I'm not sure when it is required.
Not looking forward to doing it when the time comes since I'll likely use the dealership and hope do it right unless someone writes a program for bleeding the system.
Old Dec 12, 2011 | 08:08 PM
EvoX-11's Avatar
Gotcha! Thanks for the info.
Old Dec 13, 2011 | 05:58 AM
Kracka's Avatar
Never; it's not a service item. With that said, if I keep mine for a really long time I'll get it done at maybe 100k miles just for peace of mind
Kracka's Avatar
That's the stuff; you'll use about 2/3 of the bottle.
Old Dec 13, 2011 | 06:01 AM
Kracka's Avatar
For reference:
Both the rear differential gear oil and ATF fluids are simple drain/fill jobs.
Both drains use a 10mm hex bit. The gear oil (Diaqueen 90W LSD) fill bolt is on the front of the rear diff case and the ATF (Diamond ATF SP III) is on the rear of the case.
Old Dec 13, 2011 | 08:10 AM
EvoX-11's Avatar
For reference:
Super! Thanks for the info. My local dealer has the ATF SP3 in stock so I will be picking up from there.
