Clutch Chatter
Old May 10, 2012 | 12:25 PM
BaumBizzle's Avatar
Clutch Chatter
So I scored a twin disc and took it to my shop and all the guy kept telling me is that's a great clutch but are you sure you can tolerate the chatter?...I knew that twins and othe rhigh performance clutches made noise but now he's got me worried that it's some hideous sound....I'm kinda thinking that anybody that knows car noises would hear it and be like "D@mn.....dudes got a serious clutch" but another part of me is thinking "Am I going to learn to accept it and then NOT hear other noises rattles chatters that I NEED to hear..." What do you guys think?
Old May 10, 2012 | 12:34 PM
korizmo's Avatar
Ahhh good ole clutch chatter only gets more noticeable with cams due to more engine movement from the lope. Its a sound you get when your sitting there idling. Sounds like a knock, but not everyone gets clutch chatter. I only get it when idling at 800 rpms with cams. So what did I do, upped the idling rpms to 900 and installed motor mounts. No more chatter
Old May 10, 2012 | 01:52 PM
Svendiesel's Avatar
Chatter is a beautiful thing. You'll get used to it.
Old May 10, 2012 | 02:20 PM
steinvb12's Avatar
Huh? Does it make more noise than stock? Yes. Will you mistake it for your engine blowing up? No.
It's a little chatter at idle. If you are driving, you won't even notice it unless you really really listen for it, especially if you have an aftermarket exhaust and such.
You will hear many more sounds than clutch chatter if you are driving an Evo with a bunch of aftermarket parts.
Old May 10, 2012 | 02:24 PM
YoungGrunt's Avatar
I had a pretty noticeable amount of chatter when my clutch was new but I was running cams too. Seemed to quiet up a lot over time.
Old May 10, 2012 | 04:00 PM
BaumBizzle's Avatar
Awesome thanks fella's just what I needed to hear! I have all those parts to put in (cams and motor mounts) so I guess I should be good then
EvaTheEvo
Feb 6, 2016 07:04 PM
amir008
Mitsubishi TC-SST Discussion
Apr 2, 2013 06:54 AM
omniprobe
Aug 22, 2011 05:06 PM
SupremeX
13
Jan 13, 2010 12:17 PM
travman
Jul 10, 2006 12:09 PM
